Question about Orion Car Audio & Video
Orion hcca 15.4 on a recone kit can i change it to 2 ohm dvc
steveswny
  • 32 Answers
SOURCE: orion hcca 250 digital reference
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Posted on Feb 28, 2009
etirbynnor
  • 655 Answers
SOURCE: will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
Posted on May 17, 2009
SOURCE: My Orion d-5000 amp which is wired to an Orion
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Posted on Jun 30, 2009
  • 13 Answers
SOURCE: orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Posted on Jul 18, 2009
etirbynnor
  • 655 Answers
SOURCE: i have 2 jl-w6 subs n a orion hcca 250 amp how do i run wirering
Hello brianmitchel,
From what I am able to determine, the Orion HCCA250 is a bridgeable 2-channel amp that is stable to 1ohm when bridged and outputs 800 watts RMS into that load.
The JL W6's in both 10" and 12" versions are dual voice coil with 4ohm coils so they can be wired to present either an 8ohm load (series) or a 2ohm load (parallel). They can handle 600 watts RMS.
With this combination, the best configuration would be to wire the sub voice coils in parallel for a 2ohm load and then parallel both subs to the amp bridged terminals for a final impedance of 1ohm. The subs will each be getting 400 watts.
In any event, I would not recommend running subs in series. There is some evidence for distortion being caused by something termed "back EMF".
Hope this helps.
Posted on Aug 03, 2009
I have a orion hcca 12.4, dvc 4 ohm sub, can I put a dvc 2 ohm recone kit on it even though its a 4 ohm dvc sub?
In most cases yes as long as coil and all are the same ive changed my HCCA orions from 2 ohm to 1.
Dec 15, 2011 | Orion Car Audio & Video
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
I have a 12 inch ORION HCCA dvc, 4ohm sub. My
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
Oct 26, 2009 | Orion HCCA 12D Car Speaker
How do i run a dvc sub with 2 mono amps? I have 2
each amp has + and - and will go to one of the voice coils , for the other voice coil use - to + FROM THE OTHER AMP , SET GAINS TO FULL COUNTERCLOCKWISE SO U NCAN LEVEL MATCH AMPS TO HEAD UNIT . REASON ONE VC IS WIRED "OUT OF PHASE IS SO THE CONES PUSH AND PULL WITH EACHOTHER
Oct 25, 2009 | Car Audio & Video
How many svc subs at 4ohm does it take to get this amp to 1ohm stable and can you reccomend a good sub combo for this amp whether it be dvc or svc
It depends if your sub is 4ohm svc, or 2ohm svc. 4ohm would take 4 subs wired in parallel, 2ohm would take 2 subs wired in parallel. But for a amp that big, subs that'll handle it are definitely gonna be dvc. I'd recommend 2 Orion 4ohm dvc hcca's. They come in either 15in or 12in. the 15s are louder if you have the space for them. As far as wiring goes, wire the voice coils on the subs in parallel to 2ohm per sub, then wire the 2 subs in parallel to 1ohm. Goodluck and congrats on the equipment, Orion is about as good as you can go for subs and amps. just be ready to lay down some dynamat cuz this system'll bloww your vehicle apart! good luck...
Oct 08, 2009 | Orion 2500D Car Audio Amplifier
Will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
Hope this helps.
May 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Have an old model orion amp needing specifications
the specs are as follows
250watts x1 at 4 ohms
400watts x1 at 2 ohms
600watts x1 at 1 ohm
it is bridgeable and has a 50 amp maxi fuse
May 09, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Noise when turn on and play music
Good chance that it is alternator noise mate, there is a little component that you can buy what you fit onto the alternator to stop unwanted noises feeding back threw the audio, ask in a car audio shop i would tell you the name i just cant remember it at all.
also check that all the earths are perfect, *bare metal* 80% of audio problems are due to a bad earth.
Apr 10, 2009 | Orion HCCA 250G4 Car Audio Amplifier
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Dont know what i need to install
almost any electronic stores will have an amplifier installation kit
Jan 20, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Car Audio & Video Logo
59 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
