I turn-off the a/c split type from the power plug.Now, it's unable to switch-on from the remote?what is the problem?
MODEL:HSU-18CV03-(T3)
  • 1,253 Answers
Reset the power plug
Posted on Dec 07, 2014
I have a Haier split type room air conditioner HSU-30HEA03/R2(DB) when I turn it on the display shows E7 what does this mean please.
that mean Communication fault between indoor and
outdoor units. Some wire is cut. check wires from indoor to out door unit. Open indoor unit and check cleme open outdoor unit and check it too
Nov 24, 2017 | Haier Heating & Cooling
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
I have haier split air condition Hsu 18ck03 When power supply off and comes back i manually switch on from remote.i want it auto on
Your air conditioner is not a inverter model(your model is it a low cost model )and doesn-t work automaticlly when the power is off
Aug 01, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Haier ac remote mod no hsu-18dx
MY HSU - 18 DX REMOTE IS NOT WORKING HOW TO SETUP UNIVERSAL REMOTE
May 23, 2012 | Haier Heating & Cooling
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
Apr 05, 2012 | Heating & Cooling
Looking for temperature sensor control for Haier Model DE45-RBG Numbers on part HSU-07 88A MC3A 94V-0
Here is the data sheet for the HSU-07.
http://www.maocc.com/pdf/hdk/e1321aa.pdf
There appears to be 5 different versions of the HSU-07 Let me know which one matches yours and I will try and find a source.
HSU stands for humidity sensing unit.
Keep me posted... on the actual part match per the pdf file.
Kelly
Jun 19, 2011 | Haier 45-Pint Dehumidifier
Split system air con LG model LST 2434C-2 unit won't turn on, remote is working but unit won't respond, turned on at wall.
Check there will be red icon when power is on,before switch on by emote. If no red light, there is no power goes into indoor unit. Check. If red light is there and no response with remote, communication error between remote and PCB in indoor. Try with other same type remote. If yes, replace battery or replace your remote. If no, receiving sensor in PCB problem. Repair or replace it.
Jan 13, 2011 | LG Heating & Cooling
I have a Haier split airconditioner HSU-22HD03, it runs for 5 minutes and then switches off and the power and timer light start flashing.
It shows your indoor PCB faulty. (As you didn't mention any error code). Next time count the green light flashing and write.Thanks.
Jan 11, 2011 | Haier Heating & Cooling
LOOKING FOR ELECTRICAL DIAGRAM AND OPS MANUAL FOR HAIER HSU-22VCA MINI SPLIT
I cant find the manual but I can help you this the issue you might be having. Let me know. http://www.myminisplit.com
May 14, 2010 | Haier HSU22VCA 22000 BTU Cooling Only Mini...
VCR will not switch to program mode
Solved my problem by reading a previous post about taking apart the remote and cleaning the contacts. Believe it or not it the remote is working again.
May 14, 2009 | Mitsubishi HS-U545 VHS VCR
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
