Question about Tricity Bendix Dryers
How do you replace the heating element
The rewiring
    Problem Solver:
  • 17 Answers
You can search youtube for videos on your model. They show step by step instructions
Posted on Dec 10, 2014
I have intertherm e1eh-015h I just wired up heat
when the thermostat is set more than 2 degrees higher than room temperature the auxiliary heat will run with the heat pump.
Oct 11, 2014 | Heating & Cooling
Wells 3 element commercial deep fryer. One element heats up other two do not. So all the work of heating is one element. Eventually the reset button trips off. All three tested good for continuity. Is...
Sounds like you may have a 3 phase fryer, or it is wired wrong. If you only have single phase power, it might be able to be rewired so that all three heaters are on the two main leads, this is often done at the power relay with a strap. Note the current will be much higher this way.
Jul 19, 2014 | Kitchen Appliances - Others
Red wire connect
Water heater elements have two screws and wires can connect to either screw.
Copy following link if you are rewiring thermostats:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Jun 09, 2012 | Hardware & Accessories
I HAVE CLOTHES DRYER MODEL NO. KEYW977BWHO AND WHEN I PUSH TH NO HEAT AND PUSH THE START B UTTON IT START AND THE HEATING ELEMENT STILL COME ON AND STARTS TO HEAT. DO YOU HAVE A SOLUTION TO THIS PROBLEM...
There are a few possible issues you will need a quarter inch nut driver and and ohm meter to figure out the problem. First step remove the back panel. Once your back there to ohm anything out you have to remove one wire from the device your testing. You will have a skinny white thermal fuse with two wires going to it if that has no continuity its bad replace that (3392619) and the cycle therm next to it w/ 4 wires (3387134) and check your venting because the problem occured due to over heating. The next thing is you thermal fuse located at the top of the heater housing that comes in a kit with the hi limit thermostat which will probably requere some rewiring. The last thing to check would be your heating element which is a (279827) fairly expensive but easy to replace. Also before you replace anything make sure you are getting true 240v to the dryer.
Hope this helps _MJ_
Jan 31, 2010 | Whirlpool LER5636P Electric Dryer
Trying to replace bake element on JKP15, how to do wires?
Look at them closely. If they have an opvious connector, it should slide off. If they look soldered, you will have to see what the replacement looks like to determine how you have to replace it. If it needs soldered, you will need silver solder, a torch and silver solder flux or Boraxo, mixed with water to form a paste, to be used as flux.
Dec 22, 2008 | GE JKP15 Electric Single Oven
Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Dec 15, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Blodgett oven
if you only have 3 wires to the element it doesnt matter how there hooked up.
Aug 07, 2007 | Blodgett (ZEPHAIREG-DOUB) Double Oven
Dryers Logo
60 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
