Question about LEC TS48112W White 112 l Fridge Freezer Top Freezer, A Energy Rating
Me lec fridge ice compartment is freezing up
I have turned it down to 2
  • LEC Master
  • 5,323 Answers
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
Posted on Apr 17, 2015
Whirlpool Refrigerator Model No. WRN28RWG6
if the flap was open then truely excessive cold air is coming out/escape from the freezer causing no freezeing. you need to defrost your fridge.
Note also that frost build up increases time to freeze your food on the freezer. it also causes your fridge an increase in electricity consumption.
defrost your fridge for some time ti remove the frost build-up.
Nov 19, 2007 | Refrigerators
Fridge freezing up
It may be a faulty thermostat,namely the control you are using to turn it down.Also there may be ice in the drain line from the fridge compartment to the evaparator tray at the bottom.Try unplugging it overnight .That would allow any ice buildup to thaw.Once it goes into defrost mode again the resulting water should flow into a tray at the bottom of the fridge near the compressor.
Nov 11, 2014 | Refrigerators
I have a 2 year old LEC T2856w fridge freezer and the fridge keeps freezing everything, it seems to be warmer at the top and makes a wall of ice on the back
That sounds like an a refrigeration engineer is required as if the gas pressure has dropped, it will no longer cool properly.
Mar 07, 2011 | Microwave Ovens
LEC L6046W FRIDGE - ICE/FROST INSIDE THE BACK WALL. MOTOR IS RUNNING CONSTANTLY.CLEANED ALL THE ICE OFF BUT WHEN SWITCHING BACK ON, WITHIN 10MINS THE ICE,FROST IS BACK?
1.I think you might have a thermostat problem it is over cooling the system and doesn't shut off when it is suppose to. Replace the thermostat
2.If the door seal is broken or the door is not closed shut with the seal magnet nice and tight against the fridge it will form ice inside the fridge as well. Replace the door seal. (this is very common with old fridges)
Sep 06, 2009 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
How do I fit a new freezer compartment door onto my lec R43G fridge
my freezer is not cooling like it such and ice is forming in the back of freezer
May 03, 2009 | Refrigerators
Fridge problems
There is a damper between the Freezer section and the Refrigerator sections. If the damper is open to much the refrigerator will freeze up and it will freeze food. Find this damper and close to about 1/2 way.
The Thermostat is seperate make sure this is set around the middle setting. If the thermostat is bad it can cause the refrigerator to also freeze. Turn the dial down and listen for the compressor to click off. then wait a few minuites turn it up and see if the compressor come back on. If you turn the Thermostat all the way down it will shut off with the switch. not shut off by satisifying the temp. so just turn it down slowly and see if it is working.
May 20, 2008 | Hoover HCA390FFK Bottom Freezer...
LEC TS48112W White 112 l Fridge Freezer Top Freezer, A Energy Rating Logo
66 people viewed this question
Top LEC Refrigerators Experts
mike cooper
Vernon Taylor
Are you a LEC Refrigerator Expert? Answer questions, earn points and help others
