Question about Jeep 1998 Grand Cherokee Laredo
Engine turns off by itself and then wont start after 15 minutes later
New battery, new starting coil and alt. new cap
    Sergeant:
  • 406 Answers
I had the same problem with a van I owned, it turned out to be my fuel pump was going bad...had giod pressure but would loose prime and shut down then after 10 min or so would start..One day just quit..had it replaced solved the problem...have it checked..good luck..
Posted on Dec 06, 2014
Engine turns over but wont start, getting gas, new distributor cap and button. what could it be?
it needs recalibrated,any time you put a new ignition module in a fuel injected ignition Engine,You Will Get Erratic Results.When Your Done,Do Not Take The Battery Out For More Than 15 Seconds Or You Will Loose Calibration
Jun 11, 2014 | 1992 Toyota Tercel
I have a 99 mercury cougar.recently the altinator light came on,so we replaced the alt. thought everything was good untill we started looseing power from the battery,we later noticed the alt. light wasnt...
I'm not aware of an alternator light, only a voltage gauge. It sounds like you need a new battery. Another (cheaper/easier) troubleshooter is to take the cap off of the cells on the battery itself. If the battery acid is lower than half, add DISTILLED water to raise the level then replace the caps. Sometimes a battery dries out.
Sep 02, 2013 | Cars & Trucks
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
New plugs,new dist cap,new coil new ign. control module new fuel filter ,wont start
Fuel system checked? If OK, did you "reset" the ECC also called the ECM or PCM which is the computer of the vehicle? Do it by unhooking "both" battery cables, waiting 15 minutes, rehook then try to start and see if this helps. If not you may have to start on the ground floor by checking all fuses, crank and cam sensors, ICM, etc.
Sep 01, 2012 | Volvo 240 Cars & Trucks
I have a brand new out of the box husqvarna 128ld 2 stroke trimmer. It will start and run fine for about 15 minutes and then it just dies and wont start again for about an hour. Then I get another 15...
Since the fuel cap is clear, your symptoms point to a bad Ignition Coil. Even though it it brand new, this could be the problem. I would take it back where you purchased it and tell them how it is acting . You may even suggest that you think it's a bad Coil. A new coil could cost you $40, but I sure wouldn't pay for it! I'd make them pay for it.
Good Luck!
Jim
Jul 30, 2011 | Husqvarna 28cc Gas Line Trimmer
I drove threw some flooded roads and it didnt do anything right away but about 10 miles later my car just quit working and then wouldnt start it wants to turn over but it just wont do u have any idea about...
when you went threw the flooded roads it could have got a little bit of water into your engine so take out your spark plugs and start the engine to get the water out then drain your oil and see if it looks milky if so then change your oil and let your car run in idle for about 20 minutes then change the oil again. i hope this solves your problem
Apr 09, 2011 | 1995 Ford Escort
I have a 1990bmw 325i. i turned the car off one day. ran in the store. ten minutes later came out and the car wouldnt start. left the car. came back thirty minutes later the car started. drove the car 25...
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Dec 14, 2009 | 1990 BMW 3 Series
1998 dodge ram will turn over but wont start.
just replace your alternator and you will be fine also you might check any wires hanging around just to make sure nothing touching the body ok goodluck
Aug 12, 2009 | 1999 Dodge Ram
Runs fine for approx 15 mins,then stalls out and wont start again
sounds like coil problem, coils will start cold then get hot and stop. when coil cools will crank up and run till it gets hot, try to replace the ignition coil,dont think it would be a crank sensor, try a coil,thanks robert b.
Jun 19, 2009 | 1993 Jeep Cherokee Country
Jeep 1998 Grand Cherokee Laredo Logo
78 people viewed this question
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
 Brian Main
Brian Main
Are you a Jeep Toy Expert? Answer questions, earn points and help others
