Question about Copystar Cs-400ci
How do i fix machine failure
Shutting down, cleaning
  • Copystar Expert
  • 337 Answers
What error code
Posted on Jan 08, 2015
HP Photosmart C5180 printer error message Oxc18a0206
Use your machines own programme to clean the ink heads
Feb 20, 2016 | HP PhotoSmart Office Equipment & Supplies
After I downloaded to windows 8.1 I can't connect to facebook
First, try cleaning your browser and updated Facebook work and shut down the machine, and then open it again.And in case of failure
Try to change a new browser (Google Chrome or Farfox .....)
As in the case of failure
Try again download windows 8 correctly
Nov 16, 2013 | Computers & Internet
Shuts down and gives me failure E 1 on the card and will not start
E1 = The air filters need cleaning (after 720 Hours use)
It will shut down until you clean the filters & reset the E1 alarm code.
To do this you need to:
Pull the Air Con appliance lead out of the power outlet in the wall.
Remove & Clean the air filters & then put the cleaned filters back in machine
Before plugging back in you Push & Hold the Power button on the Unit
THEN while holding the power button you PLUG the lead back into the wall.
Keep Holding the power button until you hear the unit emit a beep (hold for approx 5 secs)
Then disconnect the power supply lead again.
Then Plug it back in again & turn on
It should be cleared & working well.
Good luck
Aug 10, 2013 | Sharp AF-S120FX Air Conditioner
My Acer X110 DLP Projector shuts down with a message "fan failure"
clean the fan if you have blower do air service. otherwise open it and clean the fan.
if fan totally not working then need fan replacement.
Apr 18, 2013 | Acer X110 Projector Svga Dlp 3D, Eco,...
My toshiba laptop was recently swiped clean and rebooted running vista. Everything was running smooth.until i shut down the system. the next time at start up it didn't recognize any OS. the next t
I recommend reinstalling Vista, and replacing the Hard Drive as well. The errors being sporadic could be indicative of a hardware failure or a software failure and could be both in tandem.
Dec 09, 2012 | Toshiba Computers & Internet
Ignition control failure
Try cleaning the flame sencor first , or it could be the snap dice shutting down there are two on there you could bridge them out one at atime and see if it stays on .
Nov 22, 2012 | Mr. Heater Natural Gas Garage Heater -...
Ink system Failure Error Oxc18a0001
Hold the number 9 key and the key down at the same time, then pull the power cord. Then put the power cord back in while holding the 9 and # key. You will lose your settings, but the ink system failure message should go away.
Jan 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
XEROX Work Centre C2424 has error code 07,010.43:1559
That is a code that comes up when the print head is not piviting properly.
The 2 main causes are , 1 there is a stainless steel block on the left side of the machine which gets ink spilled into it, it needs removed and cleaned, the other issue is if there was a power failure or the machine was inproperly shut down, the wiper blade that cleans the print head between copies is stuck between the drum and prine head.
Let me know if you want to try and fix this. Its not to hard, Just somewhat time consuming.
there is a 90 percent chance one of those 2 things is causing your problem.
Sep 20, 2008 | Xerox Office Equipment & Supplies
LAPTOPKEEPS CRASHING OR JUSTS SHUTS DOWN
Sounds like it might be getting over heated. You will have to clean out the cooling system.
Aug 24, 2008 | Computers & Internet
Black line down right margin
Have you tried a new toner and drum unit? if not please do so. If that doesn't work then it is a scanner lamp failure and will need replacing.
You can fix it but trying to obtain this part for such an old machine will be hard. Don't know the part number sorry.
Thanks J
Jan 30, 2008 | Brother MFC 8500 All-In-One Laser Printer
Copystar Cs-400ci Logo
32 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
