Printer won't print print. Computer recognizes the printer', but if I try to print an e-mail, it won't print the contents of the e-mail, but will print the ad that runs down the right hand side of the screen.
  • Office Equip... Master
  • 3,368 Answers
That is not a printer problem it is a combination of your printer driver add email program.
Posted on Dec 06, 2014
SOURCE: scanning document leaves streak down right hand side
Backu
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Rowboat
Posted on Dec 26, 2007
SOURCE: Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Posted on May 01, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
  • 90 Answers
SOURCE: hp 1350v all-in-one printer won't print
if you have a print job stuck go in and hit cancel job. If it stays even after a few min right click "my computer" on your desktop and hit "manage" go to "services and applications" click "services" find the print spooler option and right click it and stop the service. Once stoped right click it again and start it. This should clear anything stuck in print queue trying to delete
Posted on Jun 22, 2009
rioglen
  • 95 Answers
SOURCE: black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Posted on Sep 23, 2009
Computer won't detect printer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X1290 All-In-One InkJet Printer
How do i get my Lexmark X2350 Printer to send e-mail? I scan my documents, but the new e-mail box does not appear after the scan like its suppose to.
Make sure that your default email program is correctly set on your computer.
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document to verify that the problem is fixed.
Nov 08, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x7550 won't communicate with computer to scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
Oct 19, 2011 | Lexmark X7550 InkJet Printer
Why won't my printer print after I installed the software? It says its ready but nothing will print
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
"Communication Not Available" message is displayed
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
My hp deskjet d1460 only prints half a page when i try to print in my hotmail page.Ive been into re-alignment & it says i don't need to re-align as I'm only using one catridge
are you able to print any document from your local computer if so your driver and your print are both fine, check print preview before printing your hotmail mails, if still not coming alright try high content to be printed only
Oct 20, 2010 | HP DeskJet 1280 InkJet Printer
Printing from the desktop of an apple G5
If still unable; got to explorer and copie and then paste in a new folder on desktop. Note Printers will print documents that are recognized by your computer. Does not print programes
Feb 27, 2009 | Apple Power Mac G5
Lexmark Z55
does an error message appear on the computer screen?
Jul 03, 2008 | Lexmark JetPrinter Z55 InkJet
63 people viewed this question
k24674
