Question about Polaroid Televison & Video
Connect a sound bar to a polaroid tv p40led14
Cant find a connection
  • 208 Answers
SOURCE: tv dont work with surround sound
It is important to remember that you will not get digital audio out unless your source into the unit is digital, such as digital tuner or Hi Def cable or sattelite.
Posted on Feb 24, 2008
  • 476 Answers
SOURCE: sound no picture Polaroid 15.4 TLA-01511c
If you take a good look at the screen when it goes dark can you make out anything maybe some bright scenes on the channel you were watching or if you press the menu key, you can see a very dim display, you might need the back light assembly or something related to it.
Posted on Jan 09, 2010
  • 8457 Answers
SOURCE: No sound on my Polaroid flat screen
Unplug,replug the tv about an hour later.Go in ur tv menu.Go to AUDIO,go down to reset it,well go back to factory setting.Ur sound should return.Not,than ur Tuner board is dead.Trires websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacenent.
Posted on May 04, 2010
alexander404
  • 276 Answers
SOURCE: I am attempting to attach a Samsung Sound Bar to
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Posted on Aug 12, 2010
sethtorvea
  • 17 Answers
SOURCE: LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
Posted on May 08, 2014
Have bought a polaroid soundbar tb301 to work with my polarooid p43d300 tv what setting do i need to set tv to
Could not find a Polaroid TB301, so we'll have to guess.
Press the Menu button on the remote and use the right and left arrows to select AUDIO.
In the AUDIO Menu, use the up and down arrows to select SPDIF Type.
If the sound bar is connected to the TVs Digital Audio Out, (it plugs into the socket with the red light) select Dolby Digital.
If the sound bar is connected to the TVs R/L Audio Out, select PCM.
Jun 29, 2016 | Polaroid Televison & Video
Has elcd42p3dl10 polaroid tv got an output
If there is no audio out socket at the TV; you can't take out the audio from it; to connect to a sound-bar. Gopakumar Gopalan Google
Jan 03, 2015 | Polaroid Televison & Video
Hello i bought a sound bar its a phillips cant get any sound out of it tried another tv same thing
Most sound bars are connected from the TV via the audio output. Try connecting out from tv with Toslink or optical cable. This should operate all of your tv audio.
Jan 03, 2015 | Toshiba Televison & Video
Polaroid led tv ssdv311-11 sound but no picture, connected thru cable box
The TV electronics for the picture may have failed. Do you get any picture ever, like when you turn it on, or when you connect a DVD to it?
If you do then replace the scart cable with a good known brand. Cheap scart cables often do not have all the pins connected up.
Dec 21, 2013 | Polaroid 1521-TLUB LCD TV
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Televison & Video Logo
76 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
