Question about Philips DVDR3390/37 DVD Recorder
Failed to stop recording problem
I have a Phillips DVDR3390 Recorder. Through a DVR cable, I play my Sony Handycam video recorder so that I can make DVD's out of my home movies. I had problems with my former Phillips recorder so sent it back for repairs. The old one was outdated so I got this new one. It has worked a few times since I have had it, but lately it does not work at all! Every time I hit stop at the end of a DVD recording, it says updating, and fails to update. When I go to the disc menu afterward, it tries to recover the disc, each time unsuccessfully. I have about had it with this and am ready to go buy a new one (NOT A PHILLIPS), but want to know if there is something I am missing here. I know that it has worked before exactly the way I am using it now. Thanks, Derek
  • 38 Answers
Re: Failed to stop recording problem
I also bought this when it was new. I also paid about $150 for it and also had the exact same problem after a while. It seems that after so many hours some of the features stop working. However, through trial and error, I have discovered that you can still record using DVD-R only. For all the boasts of DVD /-R and DVD /-RW, it does not work after a certain amount of time. Philips does indeed have the worst customer service I have ever seen in any company out there. Contacting them is a nightmare and pure hell. I do hope that no one ever buys any of their products again and I also hope this little bit of info I posted helps someone.
Posted on Sep 25, 2010
0 characters
3 Points
I have the RDR-VX530 video cassette recorder/dvd recorder and a sony DCR-TRV520 digital handycam and i cannot get it to transfer the hi 8 video to a dvd. i use a dv in/out cord and not sure what the...
Check video input setting to DVD recorder...should be set to "External" or "Line". This should activate the video input jacks on the rear of the RDR-VX530 and allow it to "see" your Sony handycam.
Nov 08, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Pioneer dvd recorder dvr 310
Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
Try this and let me know if it works.
Mar 27, 2008 | Pioneer DVR-3100 DVD DVD Recorder
well there the first thing i would check is the audio connection..
basically if you are recording from a playing media, like a dvf player
it would be like this
audio and video out from the dvd player to the inputs in the recorder.. then the out puts from the recorder to the input in the tv... (just a refrence)
upload your diagram, and state exactly what you want to record from.. if its the tv or another media type..
If its from the tv,, lets say you got cable and you want to record from cable,, Its
connect the out put from the cable box to the input of the dvr, then the out from the dvr to the input of the tv..
if its from an arial
connect the arial to the dvr,, now connect the dvr to the tv,, I guess you got the picture of what i am saying..
Basically all the out put from the media you wish to record from to the DVR and then from the DVR to the Tv..
Feb 22, 2008 | Samsung DVD-VR357
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp DVD & Blu-Ray Players
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Feb 12, 2009 | Sony VRD-MC5 DVD Recorder
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Sony RDR-GX300 DVD Recorder > cant progamme channels to record
is the dvr burner hooked up to cable directly or is it coming from a cable box through video cable or again from coaxle cable?
Nov 24, 2007 | Sony RDR-GX300 DVD Recorder
Philips DVDR3390/37 DVD Recorder Logo
425 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
