Question about Sony Televison & Video
The feed into my apartement is a community system of mixed analogue and digital programmes..my sony rm-y1002 tv will not tune in to all the channels....help ??
  • Sony Master
  • 3,368 Answers
Get a different TV or a converter box.
Posted on Dec 06, 2014
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
I have lost digital reception. I can play DVDs and get analogue TV.
You need to make sure your reception is strong enough to receive digital reception otherwise you will only receive analogue reception and dvd playback ability is normally nothing to do with the TV's reception.
Ensure you have strong reception before doing an auto tune to search for the channels. Good luck.
Sep 14, 2010 | Sony KDL-52XBR9 52 in. LCD HDTV
How can I get an analogue signal on my LG3000 32in LCD tv? Digital input is fantastic, but no idea how to obtain analogue. Input is connected to a community arial and other residents get analogue with no...
According to the manual I looked at, this TV has only one antenna input. This means that analog is available if you let the TV do a full autoprogram of memory. It might take it several minutes to complete, but once its done you should have analog and digital if available. If you were looking for analog channel 5 then you would just enter 5-0 but digital channel 5 would be 5-1.
Nov 12, 2009 | LG 32LG30 32 in. LCD HDTV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
