Question about Hoover Optima 7 OPH716DF White 600 mm Washer Front Loading, 7kg, A Energy Rating
One of the bars inside the drum has come loose how do i fix it
Tried gluing it but has come appart
  • Hoover Master
  • 1,249 Answers
Open the shell, find what screws fell out, replace screws tightly.
Posted on Dec 07, 2014
I have an 84 honda accord and the defroster cord came appart while taking the headliner out... Does anybody know how to fix this? Please help if you can :)
they make repair kits for this. it must be glued back to the window and then the circuit must be completed with a repair kit.
Nov 18, 2012 | Cars & Trucks
Felt ring falling out of door, kenmore he 4 dryer
The felt seal is glued onto the rear of the drum . If it is torn then it will need to be replaced . If it just came loose it may be re glued.
Feb 26, 2011 | Dryers
I took my washer all appart to clean the gum out of the tub now the spin cycle hits and bangs the sides so much you cant use it
Assume this is front loading washing machine, Check drum dampeners are firm, any cables that were held by cable ties near the drum and were removed in order to remove the cables in order to access the drum need to be replaced with new cable ties, there shouldn't be anything loose dangling around near the drum, as it will strike when the drum vibrates during its spin cycle.
Jan 15, 2011 | Kenmore Washing Machines
Beater bar in the dryer came loose how do we get that fixed?
If you are referring to the baffles inside the dryer drum, they are attached with mounting screws along the outside perimeter of the drum. This is a very simple repair that anyone can do without the assistance of a repairman. You will need to lift the top panel of the dryer to access the drum. You may need a second set of hands to hold the baffle in place while you screw it back in place. If you need assistance on how to figure out how to get inside the dryer to access the drum, please post back with a complete MODEL NUMBER. I hope this helps you.
Jul 01, 2010 | Dryers
Dryer drum has come loose, how do I tighten it?
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
Jun 27, 2009 | Frigidaire FEX831CS Top Load Stacked...
I have a Kenmore Dryer. I've already diagnosed the problem. Its the solution that is in question. There are three metal rectangular things glued on the outside of the drum. they are roughly 5'' by 12'' and...
What is the model of the machine? That is somewhat common. I have seen some that do nothing at all and I have ripped them off or some are part of the moisture sensing circut. If you stick you head in the dryer and see 2 metal strips under where the door closes, inside, those are the moisture strips and you can take the glued ones off. Let me know if you need any more help
Mar 08, 2009 | Dryers
My Bass Drum trigger just stopped working .
this is an easy problem to fix. The piezo piece on the inside of your bass drum trigger uses a double sided tape that is fixed to a metal disc. the piezo trigger just fell off. mine did the same thing. I actually glued mine with epoxy and have not looked back.
Nov 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Kemore Elite HE4 Dryer
Hi! juysu
Please check the power cord, by checking if there is 240V on the power terminals inside the back of the machine where the power cord is connected.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Clothes getting caught between Tub and wall inside dryer
there is uaually a rubber or composite gasket that fits inside the dryer drum with the front cover in place. the "rollers" as you call it is just pieces of felt glued to theexternal drum and front face and are the drum bearings. check appliance repair parts for the proper gasket and how to mount it to your front panel.
Dec 28, 2007 | Frigidaire FDE336RE Dryer
Hoover Optima 7 OPH716DF White 600 mm Washer Front Loading, 7kg, A Energy Rating Logo
47 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
