Question about Health & Beauty
I have a sterling diamond scooter. How can i use jump start to charge the battery? Is there any emergency portable charger to carry if i get stuck outside and there is no car or power.
    Problem Solver:
  • 18 Answers
If the batteries have been alowed to run down too far.when you plug the charger in the electronics in the charger will look for the 24 volts +/- 2 volt at the charging socket.if it dosent find this it will not supply a charging current to the Batteries.2 possable options here ,if batteries have not been left too long they may bump start,remove both batteries.either charge each battery individually with an old analogue 12volt 5 amp car battery for 1 hour each , then refit and try mobility charger or if a 12v smart charger avail and wont charge temp jump start charging with a good 12volt battery conected in parallel with the faulty one +to+.._to_ if both these methods fail the batteries have been damaged beyond repair and both will need replacing. keep new batts charged evrey time you use it and charge for min 10 hours. to avoid dammage and failure to replacement batteries
Posted on Jan 16, 2015
  • 3,368 Answers
It might be easier to carry a spare battery. I am not familiar with your unit. I do not understand how a jump start would work without an external power source.
Posted on Dec 06, 2014
Why dose my battery charger start for a second and click of
Could be scooter battery voltage is too low for charger to charge battery.
(It is a problem with gel cell batteries I have got a scooter that won't charge at all at home am going to try jump starting with another battery to fool the charger but I might have to buy new batteries.The Nursing homestaff took the scooter off my father in law and left it in the shed to get nice and flat instead of leaving it on float charge I should send them a bill for new batteries
Sep 16, 2014 | Health & Beauty
Can a Duralast jump starter kit start a car while plugged into an outlet?
The charger to a Jumpstart charges at a low rate (300mA to 500mA) and will not push enough current to start a car. Best to have Jumpstarts recharged every 6 months to be ready for emergency.
Nov 26, 2012 | RoadPro Road Pro 12 Volt Dc Portable...
We have just put dads Sterling Classic back together after months standing idle. When we switch the battery charger on it says check but what do we need to check.
Hi. The main thing to check for is that the charger is actually connected to the batteries. If the charger has a 3-pin plug that plugs into the scooter, check that there is no broken wires in the plug. Also check the socket in the scooter with a multi-meter, you should be able to read the battery voltage from the meter.
Most chargers sense the voltage in the batteries, and base the charge rate on this voltage. If the charger is not connected to the batteries when it is turned on, it will drop out and go into a fault mode.
Good luck. Neil.
Jun 26, 2010 | Health & Beauty
My Schwinn S-180 scooter won't charge
Check your charger with a meter and see if it is putting out the correct voltage for your scooter battery. If it is, you probably need a battery, probably so anyway after 2 years. Good luck!
Mar 16, 2010 | Transport Schwinn Rechargeable Portable ...
So, my 150cc Chinese scooter has been acting like the battery in really low. I have been kick starting it for a couple of weeks. Today, the kick start level disengaged so now I'm really stuck. I got a...
Did you remove the battery from the scooter before charging? The scooter circuitry may be giving the charger false readings.
Can you try to jump start the scooter using a car and some jumper leads? If it starts that way, then your battery is dead.
Jul 26, 2009 | 2006 TN'G Low Boy 150
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
Can't charge my e-scooter
ok you do not need a new charger. the problem is you let the battery get too low. the battery has to have a little bit of power left in it to send to the charger, if it dosent then the charger can't tell if there is rilly a battery hooked up or not. you shuld probubly get a new battery. or you can email me and i will tell you a few things you could try to jump it back to life.      wildnfuzzy@gmail.com
Jan 24, 2009 | Transport Schwinn Rechargeable Portable ...
Sterling sapphire 2 4wheel scooter
Larry,
Many scooters use a special charger that will not overcharge the batteries. Your best bet is to run a long extension cord to wherever you are safely storing you scooter and use the on-board charger. Be sure to charge your batteries often, since they last a lot longer if you do not run them down too far.
Oct 27, 2008 | Health & Beauty
Health & Beauty Logo
103 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
