Question about Garden
How big wrist pin
I need piston
    Sergeant:
  • 192 Answers
What make and model and size engine of chainsaw do you have?
Posted on Dec 28, 2014
I have a2005 yamaha fz1 and the wrist pin is stuck on the stator side of the case. How do I remove it?
I am not sure if you are referring to the correct part, but the wrist pin connects the piston to the connecting rod (piston rod). If you truly have a frozen wrist pin the only way to correct it is to remove the piston from the cylinder. On some engines the cylinders can be removed without disassembling the case, others can't, but this is not a job for the casual mechanic because it involves the timing.
Feb 23, 2017 | Yamaha Motorcycles
05 Dodge Neon 2.0 Head gasket fail between #3 and #4 cylinder.
YES SOUNDS LIKE A FAILED WRIST PIN, PISTON SLAP IS MOVEMENT OF PISTON INSIDE OF CYLINDER
Feb 22, 2017 | Dodge Cars & Trucks
What is the wrist pin size
unless you have pulled the motor apart , talk with a service dealer as they may have a wrist pin (little end pin ,conrod pin) in stock that can be measured
normally they come with the piston as a unit
Sep 06, 2015 | Garden
I do not havbe hyd press. Is there any other way to press the pistons off the connecting rods so I can install my new pistons, without damaging the new oistons
with press fit wrist pin pistons the only way is the use of a hydraulic press and they will have to be checked to make sure the wrist pin and piston is centred to the con rod.
Aug 29, 2014 | Cars & Trucks
Making knocking sound
A KNOCKING SOUND IN THE ENGINE IS MOST LIKELY CAUSED BY ONE OF THE FOLLOWING
1. PISTON SLAP: Makes a sharp metallic noise. Idle engine and short out each cylinder plug. The noise will disappear when plug with bad piston is shorted. Noise will also disappear at acceleration. This can be caused by worn or out of round cylinder, or broken piston ring. Correct problem by re-boring cylinder and/or replacing piston.
2. VALVE NOISE: Makes clicking or rattle noise. Caused by excessive wear on valve stem or lifter, out of adjustment, or stuck valve. Correct by adjusting valve clearance, replace worn valve or lifter, regrind cam, replace valve guide and /or valve. A stuck valve can sometimes be loosened by passing oil through the carburetor while engine is running.
3. ROD BEARING KNOCK: Makes sharp metallic noise similar to a piston slap. Detection is opposite of piston slap. Rod knock is not heard at idle. Knock becomes louder as engine speed is increased. Caused by excessive rod bearing clearance. Correct by adjusting rod bearing clearance to .0015 inches by removing shims. May require re-pouring rod bearing.
4. REAR MAIN BEARING KNOCK: Makes dull knocking or thud noise. Detected at speeds between 20 and 50 MPH. Knock will normally decrease or disappear while pulling or decelerating. Noise will be detected the loudest at normal driving speed, when not pulling or decelerating. Correct by adjusting bearing clearance to .001 to .0015 inches. If knock is excessive, crank should be checked for out of roundness. May need to re-pour all main bearings to correct.
5. TIMING GEAR KNOCK: usually the most difficult to diagnose. If gear is loose or badly worn it will knock in all ranges. Run engine slightly above idle speed. Slowly open and close throttle. Knock will continue to be present, but just as engine slows down knock will become a slight rattle. Remove timing pin and reinsert into timing hole on timing gear cover. Press timing pin tightly against timing gear and accelerate slightly above idle. Knock will significantly be reduced or disappear. Correct by replacing both timing gear and crank gear as a matched set. The two gears should have a backlash clearance of .003 to .004. If more than .009 inch backlash, an oversize (.005) timing gear should be installed.
6. WRIST PIN SLAP: This can not be detected by shorting out the cylinder plugs. Rapidly accelerate and decelerate the engine speed. The engine will pass through a certain speed range when the wrist pin will rattle at about the same pitch as a valve tappet noise. This can be corrected by installing a new wrist pin bushing in the rod or new wrist pin f badly worn. Wrist pin should fit the piston and connecting rod with a tight metal to metal fit. The pin can be pushed into the piston and rod with a slight pressure of the hand. Pin to rod clearance is .0003 to .0005 inches.
Dec 06, 2013 | Nissan Cars & Trucks
V6 knocking noise
Dec 06, 2013 | Cars & Trucks
How do you remove a stihl piston
You pry out one of the wrist pin circlips with a small pick tool, being careful not to let it fly away. Then, you use a 1/4 ratchet extension to hammer it out using a ball-peen hammer. You'll want to support the other side of the piston, so with your hammering, you don't damage the piston or the connecting rod, or the bearings, and it's a handy place for the wrist pin to fall into. I suggest a deep-well 1/2" socket.
May 25, 2012 | Stihl Chainsaw 42mm Piston Rings 025 O25...
Still have a slight knocking noise after replacing all big end bearings.main bearings are perfect.can be heard @ 2100rpm.gsr 4g93t
did u test the oil pump n r u using the rite libricant--was everything torqued to specs-did u hav a shop manual
Sep 06, 2010 | Mitsubishi Lancer Cars & Trucks
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
