Question about Russell Hobbs Kitchen Appliances - Others
My Russell Hobbs is not toasting anymore, everything else is in good shape. I need to open the case to check the elements, and possibly replace it. Where can I have a technical manual to maintain my n
Taken the glass panes off, don't know how to dismantle the toaster without breaking it. I am looking for a manual, and or lead to be able to open the case.
  • 537 Answers
SOURCE: Russell Hobbs Toaster Model # RH4T9379
It would be NICE if you didn't abort the chat session when I was tyring to help you. Geez!!
Posted on Dec 03, 2007
  • 3 Answers
SOURCE: Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Posted on Mar 28, 2009
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
  • 51 Answers
SOURCE: Russell Hobbs 10617 led bar
Well.
Heres my two bob... This is not a solution but may help someone.... I copied this from my post to another question dealing with the same toaster and problems... Also, I noticed that, in simo_tomic post, he refers to the chip in question as an 63AB1B , whereas mine the label was blank or ground off.
I havent found a source for these yet. Anyway.... onto original post...
I've tried to repair one of these toasters today.
It would intermittantly work, eg led lights would work, and the toaster would actually stay down.
Most of the time however, no lights, no toast staying down.
By removing the power cord and re plugging it in, occasionally the leds would light, then the toaster would work, until it stopped again.
FIRST A WARNING! YOU CAN KILL YOURSELF IF YOU PULL APART A TOASTER, THE VOLTAGES ARE DEADLY, IF YOU DONT KNOW WHAT YOU ARE DOING DONT OPEN IT! GET AN EXPERT OR GET A NEW TOASTER.
I pulled it apart, which was a pita as they used 8x non standard screws on the bottom.
On the pcb board where all the leds are, there is a large 18 pin chip, labelled MCU.
I believe that this is the culprit, as all diodes, resisters, caps seem OK. The thermister is ok.
By shorting two of the pins on the mcu, the leds would light up, and the toaster would actually keep the toast down, and therefore work.
However, the B**stards at Russell Hobbs have chosen not to label that chip, or have ground off the label, to make it harder for people like ourselves to repair.
Plus the fact that they use security type screws to keep us out.
This should be criminal, as it just encourages waste.
For futher info, I shorted pins 4 and 5 briefly, (ie looking at the toaster, the 4th and fifth pins on the top/far side of the pcb board, counting from the right hand side).
When I short these pins the toaster leds light and it works, not a permanent fix however.
Anyone know a suitable replacement for the MCU in this unit?
Posted on Jun 16, 2010
SOURCE: What is the part number
The ICU is a 16C56-02 microprocessor. However, I don't think you can just swap chips - it has to be programmed first, so unless you have an eprom and know the correct code....
If all of the lights work, and the toaster works, but the lever doesn't stay down (seems to be the common issue), I would try resoldering the transistor legs on the circuit board. The transistor is used to switch the magnetic solenoid that controls the lever. Mine had a cold solder joint, and when I resoldered, it worked fine. Wouldn't be surprised if they put out a whole bunch of boards with the same issue. Good luck.
Posted on Sep 04, 2010
How to enter code
instructions - Russell Hobbs
uk.russellhobbs.com/pdf/14590_stylis_black_kettle.pdf
2 Don't put the kettle, stand, cable, or plug in liquid. ... 4 Don't open the lid while the water is heating. 5 Don't ... 8 Put the kettle on the stand - take care not to spill. .... To avoid environmental and health problems due to hazardous substances in electricaland electronic goods, appliances marked with this symbol mustn't be.Missing: code
Kettles - Russell Hobbs
en.russellhobbs.com > Our Products
Over the decades, Russell Hobbs has been at the forefront of quenching our national thirst for hot beverages with fast, easy to use, great looking electric kettles.Missing: open ‎question ‎enter ‎code
Russell Hobbs KE9000S Electric Kettle, Stainless Steel
www.amazon.com/Russell-Hobbs...Electric.../B00A15...
Amazon.com, Inc.Amazon.com: Russell Hobbs KE9000S Electric Kettle, Stainless Steel: Electric ...
Jan 13, 2016 | Russell Hobbs Kitchen Appliances - Others
My Russell Hobbs electric kettle 14943 has stopped working? Fuse changed to No avail what could be wrong
The heating element has probably failed. You can check the continuity of the element with a multimeter.
Apr 29, 2015 | Russell Hobbs Kitchen Appliances - Others
My Russell and Hobbs Professional iron is only a few months old but has suddenly stopped heating up although the power indicator light still comes on. Unfortunatley I have lost the receipt but don't...
it is important to check the continuity of the coil as the power indicator is a neon and will show up as the power comes to the circuit. So what is required is to check if the coil or the thermostat control is defective and so does not heat.
If you can contact the Russell hobbs web site - support and post the part code of the set it will be traced to be under warranty and it is possible that you can get support for help...just in case the coil has opened.
Apr 01, 2011 | Russell Hobbs Irons
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
bought a new toaster I would like any account you have created for me to be deleted. thank you
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Apr 01, 2009 | Russell Hobbs Toaster Ovens
Heater Element Replacement
Yes I think they do but these may also be unavailable. You could try sourcing 'after market' replacement elements, these are universal fit elements often from the original suppliers and cheaper too. Try searching the web for Russell Hobbs replacement kettle elements.
Oct 14, 2008 | Russell Hobbs Kitchen Appliances - Others
Neville
Welwyn Herts
Aug 25, 2008 | Russell Hobbs 9209 Classic 4-Slice Toaster
Kitchen Appliances - Others Logo
65 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
