Rukohere is the code C6BWS that shpulf work if not its getting reyurned tomorrow cause i have 2 and never went thur this
Leta set this up or I'm goimh to quit cauause I'm board already
    Master:
  • 560 Answers
What language was that?
Posted on Dec 06, 2014
2006 5.7 545rfe trans. Last wed replaced solenoid block pack. Went great wed, thurs but friday morning got po700 and po876 code and has gone in limp mode. Any suggestions? Please help
Possible front transmission pump getting bad. This will also cause accelerated wear on the clutch packs. Talk to your local Tranny repair shop for advice. The solenoid/pressure switch assembly you changed relies on pump pressure for its operation.
Aug 22, 2015 | Dodge Ram 1500 Cars & Trucks
Last summer we installed a Intex salt water filter it worked great for about 2 1/2 months. It stopped working, Checked the power supply nothing was coming thur it. Intex relpaced it under warranty. Started...
This could be a flow problem and you will need to check your pump baskets for junk and make sure your filter is clean. Also you can check your flow switch to be sure it is working.
Aug 13, 2011 | Intex Automatic Salt Water System for ...
How do I reyurn my computer back to factory settings with out the ariginal set-up discs
You can contact the computer manufactor for restore disc. They will normally charge a small fee for the disc.
Aug 10, 2011 | Computers & Internet
My 2003 Cadillac DeVille service engine light came on after I took my car Thur the car wash and it will not turn off. Its been on all day after I went Thur the car wash
Hello jpritchett.
Water has entered in a circuit in your fuel injection and emission system and shorted it.
The computer has detected the fault and set a code.
There are a couple hundred different codes it could be.
Your choices are,
(1) do nothing (if it runs OK) and it may eventually dry out and reset after a hundred starts or so after the problem goes away.
(2) get it scanned at an Autozone, or similar store that does free scans.
(3) have it properly repaired at a good service center so it doesn't happen again the next time.
If you would like further advise on this, ask me in a comment.
Thank you for using FixYa.
KL
Mar 07, 2011 | Cadillac DeVille Cars & Trucks
Engine light was on 2007 mazda 3 on wed and thurs..then went off friday....do i need to bring my car to the auto shop?
Take it to auto zone they will be able to scan the vehicle, and their scan tool should be able to show pending and history codes to see codes that may be set soon or codes that have been set up the symptom causing it has stopped.
Jul 02, 2010 | Cars & Trucks
Honda Odyssey 2005 sliding doors won't open, beep 3 times
If you click once your remote control ,will open just driver side doors.To unlock all of them have to press twice , and then sliders.
Apr 11, 2009 | 2005 Honda Odyssey
Obtaining passcode
The easiest way around a lost passcode is to reset the router to factory specs. You will normally find a reset switch on the rear of the router closest to the power connector. You will probably need a paper clip or similiar object since most are resessed to avoid accidental resets.
Mar 24, 2009 | Belkin N1 Vision Wireless Router
52 rear Projection RCA-Convergence auot cycle not working?
It's late but try unplugging TV from a/c outlet for 5 minutes,if no fix call factory authorized service center. Good Luck, God Bless.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
