Question about Exercise & Fitness
How do i set 6 hour intervals that last 30mins on microrex t31?
How to set legrand timer switch 12 hours model # 037-55 microrex qw31
QW31 is 7-day analog timer, 230 Volt
http://waterheatertimer.org/How-to-set-timers.html
If there is a photocell override, then it will be wired into terminals U1 and 4, and will not be part of the timer setting
Gene
Water Heater Timers Save Money
Oct 15, 2014 | Legrand Ivory Universal Timer Controlled...
How to assemble Microrex T31?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 24, 2014 | Hardware & Accessories
I just got a riding mower (D100) and it has 7 hours on it but the service notification just came on....i checked and it has oil. The belt came off while mowing last weekend but I put it back on and it...
Here are the is the process that the notification will appear:
How Does Your Hour Meter Function? Model Year
Model Number and Product Identification Number Groups. Is the tractor equipped with an hour meter? Does it accumulate hours with the key switch left "ON", but not running? How long does the service reminder (SVC) display before and after service intervals? Does the Hour meter stay lit or display hours when the key is in the" OFF" position? Does the hour meter only count hours when the engine is running? 2008 - 2011 D100 D110 D120 D130 D140 D150 D160 D170 LA105 LA115 LA125 LA135 LA145 LA155 LA165 LA175 Yes No half hour No Yes
The notification should last for 30 mins before and 30 minutes after the service interval before it stops flashing. It is not resetable.
It does make one wonder why it started flashing at 7 hours vs 25 or 50 hours though. Possibly a battery was replaced and the running trime vs the service time intervals are not syncronized.
The service (SVC) arrow indicators will last for 1 hour. It will display ½ hour before the specified service interval and one 1/2 hour after the specified service interval.
The left "SVC" arrow will occur at 25 hour intervals (25, 50, 75, 100 etc.).
A "SVC" arrow pointing to the left will indicate that a general lubrication interval has been reached.
The right "SVC" arrow will occur at 50 hour intervals (50, 100, 150, etc.).
A "SVC" arrow pointing to the right will indicate that service is necessary for the mower and the engine.
Thanks for choosing FixYa,
Kelly
Thanks
Jul 16, 2011 | John Deere Garden
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
How do i reset and work my polar t31? I have lost instructions and it is 2 years since I last used it
There is no reset on the T-31 chest straps and transmitters. If the battery is functioning then you simply put it around your chest (make sure the contacts are wet) and turn on the watch. A heart rate signal should appear automatically.
If this doesn't work, I have solutions in my tips and tricks page as well as Manuals for Polar products. The T-31 battery may also be dead, in which case you will need to replace.
The picture you have showing is for a S-Series Speed sensor for the Bike. If this is something you are having a problem with feel free to send me a note related to the problem.
Dec 14, 2010 | Polar T31 Transmitter and Belt Set
Why are there 6 hour 8 hour an 10 hour timers to defrost a self defrosting refrigerator
Good day,
The decision as what the time interval of a timer should be is determined by engineers and field tests.
There is more to the timer than interval. Timers are usually listed as 8 hours 21 minutes, 8 hours 30 minutes ect. The minutes is used to designate the time the control stays in defrost.
A general rule is if the interval is longer, the minutes in the defrost cycle is extended to compensate.
Other factors come into play such as the wattage of the defrost heaters and the defrost thermostat temperature.
The trend today, with timers is to extend the interval to make the machine more energy efficient.
There is never an issue to defrost more often then the original, but it will run the heaters more often, and cause increased operating cost and shortened heater life.
The short and long of it is you can use a 6 hour timer in any machine if the timer motor wiring is the same and the duration is long enough, but with the costs listed above.
Jul 22, 2010 | Jenn-Air Refrigerators
Brand new came in the post 30mins ago plugged in to mains brilliant works fine played with the remote and turned off via remote. no wont turn back on tryed removing all power sources light flashes when...
It looks as if your battery needs to be charged. First charge should lasts long enough. Aproximately at least 6-8 hours. Then try to use it. I think it will work.
Regards.
Apr 15, 2010 | Katadyn Kata CC-191 Camcorder Shoulder...
I faxed something last week and lost the transmisson verification report, can it be re-printed? does my fax keep it in memory?
It's possible to print a Fax Activity report which would show both incoming and outgoing fax activity. To do this, do the following:
  1. Press Reports
  2. Use arrow keys < > to select 3. Fax Activity
  3. Press Set
If Fax Activity hasn't been set up, do the following:
Setting the Fax Activity Report Interval
You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF, you can print the report by following the Steps in the next page.
  1. Press Menu, 2, 4, 2.
  2. Press or to choose an interval,
    and then press Set.
    (If you choose 7 days, the LCD prompts you to choose a day at which to begin
    the 7-day countdown.)
I hope this enables you to recover your transmission report. Please post back with any questions or just to rate the solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Polar heart monitor T31
This link will answer all your questions...scroll down about halfway to customer info click on and then scroll the rest os thw way down....I hope this helps.
http://www.heartratemonitorsusa.com/Pages/TRANSMITTERS/T31-coded.html
Jan 31, 2009 | Polar T31 Transmitter and Belt Set
Exercise & Fitness Logo
99 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
