Question about CADAC Grilling
I need to unblock the gas veins in my cadac braai pan purchased in the year 2000
The gas from the cadac propane bottle will not pass through the veins in the pan. I can see a lot of rust in the vents. its difficult to get in to the vents. I have used a hammer to try and unblock the rust.The gas does go up the pipe but the orifice exit point wont ignite when I light the flame
SOURCE: smoky mountain series propane smoker
Solution #1 is the answer -- replace the regulator. The problem is that the regulator is stuck closed. You can either replace it, or pop the little metal cap on the top off and adjust it. (Use a large philips screwdriver). Do a full turn counter-clockwise, and then 3/4 of a turn clockwise.
Posted on Apr 06, 2008
SOURCE: Veranda gas grill - won't light or low flame
One of the major problems with propane gas grills, including the Masterbuilt Veranda, is the pressure regulator. They get to where they do not release enough propane. Some, most, have an adjustment screw that will let you correct these problems. I think I replaced my Veranda regulator with another older pressure regulator from an old grill. Makes you crazy if you don't know this.
Posted on Jun 25, 2009
SOURCE: cadac eazi chef flame burns yellow and makes a lot
Yellow flame = not enough air. (Remember using Bunsen burners in school science lab? Air hole closed = yellow flame). Have you twisted the main metal tube (whilst trying to remove the burner assembly)? Remove the gas tube and metal plate (6 small cross headed screws). Draw out the gas valve. Look into the metal tube. You should see 3 slotted holes - the air holes. On mine they had twisted and were blocked by the plastic of the leg assembly. Using a good pair of pipe grips, rotate the metal tube until the air holes are clear. Then re-assemble. My Cadac Eazy Chef now works like new.
Posted on Aug 23, 2009
bulldogchief
  • 388 Answers
SOURCE: Propane grill wont ignite
Well, it sounds like your grill is experiencing vapor lock. Vapor lock is basically air caught in the gas line and there is a relatively easy method to fix this. I want you to try this method and tell me what you get, ok? First, open the tank's valve, then open the burner valve and light the grill. Immediately after you see a blue flame, turn off the tank's valve, count to five and then close the burner valve. Repeat this procedure three times, the problem should clear itself.
If you are still experiencing problems, the regulator may be faulty and needs to be tested next, so go get a new regulator from your Lowe's and run the procedure again. If after all this, you are still experiencing the problem, let me know here. Good luck!
Posted on Jan 07, 2010
SOURCE: Hi, I am problems with my Cadac Carri Chef bbq.
I brought a Cadac grill BBQ about 2 years ago. We used it on the weekend and found that it wasn't getting hot. to our surprise it wasn't burning properly. there was no blue flame just a flame which made all the nuder neath turn to soot and very black. We took it apart and found that where the cylinder slides into the top of the cooker, that inside the sylinder is a blue plastic molding which has melted. there should not be any heat at all in this area, so can any one help with why and how 2 fix it.
Posted on Jun 12, 2011
Can i convert my cadac safari chef from hp to lp
Vinnie, first lets take a look at what HP gas is, as opposed to regular LP Gas.
HP Gas is a Propane / Butane mixture liquefied under normal ambient temperature and moderate pressures. It is a safe, clean burning, reliable, high calrofic value fuel. In addition to it use as a domestic fuel, it is also widely used in industries, where there is a requirement of low sulphur content fuel and fine temperature controls. HP Gas conforms to IS:4576-1999 specifications.
Converting your grill to HP Gas may be possible, but there would need to be some adjustments to the burner's venturi valve. As the air to gas mixture may be different. Also, you would need to check with your HP Gas Provider, to see if a different pressure regulator would be necessary.
Hope this helps you and Happy Grilling!!.
Jun 27, 2011 | CADAC Safari Chef Portable Grill
Which gas is recomended for use on a cadac eezy chef as mine is generating black smoke on propane
You get black smoke - and other unwanted & unexpected effects -
'cause 'false draft' occurs during mixture process in the venturi pipe,
PREVENTING THE BURNER FROM 'INHALING' ITS SPECIFIED
PERFECT COMBUSTIBLE HIGHLY CALORIC GAS/OXYGEN MIX.
THIS MIXTURE PROCESS CAN BE IMPROVED BY FOLLOWING
THE INSTRUCTION AS OBSERVED IN THE YOUTUBE VIDEO
'THE CADAC LEGEND',
AS PUBLISHED AUGUST 15, 2011.
May 03, 2011 | CADAC Safari Chef Portable Grill
Cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Oct 08, 2009 | CADAC Safari Chef Portable Grill
Cadac eazi chef flame burns yellow and makes a lot of soot.This happened after i tried to light it and there was some kind of blow back and some smoke but no visible flame. I have striped it down as far as...
Jul 01, 2009 | Grilling
Cadac safari chef
Hi Paul
I asked the same question and found this web site which sell a propane regulator.
http://www.flogas.co.uk/buy-online/gas-barbecues/cadac-carri-chef-deluxe-combo-8150/
Cheers
Sepp
Jun 11, 2008 | CADAC Safari Chef Portable Grill
Cadac carri chef
Hi Ronaddo, where are you living?
Jun 01, 2008 | CADAC Grilling
Convert to LP (propane)
Contact Miele directly via their website. This would require an orifice change if it is possible for this appliance. Since natural gas, butane, and propane are all forms of LP (Liquified Petroleum), it is usually, but not always, possible.
Oct 15, 2007 | Miele 35 in. KM326G Gas Cooktop
Grilling Logo
49 people viewed this question
Top CADAC Grilling Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a CADAC Grilling Expert? Answer questions, earn points and help others
