Question about EA Sports FIFA 15 - Xbox One
I cant connect to the es servers every time I click on a player in my squad it lags me out
Clicking on my player but it lags me out
Game disconnected: you were kicked by PunkBuster. Stated reason: PunkBuster kicked player 'GeT_RiGhT_H' (for 0 minutes) ... RESTRICTION: Service Communication Failure: PnkBstrB.exe initialization failed
That means that you were on a private server and either that person kicked you for too much lag (slow connection between your connection and his), or most often that is what happens automaticly when a server admin sets ping time (lag) limits to bump players who weren't getting a clean connection to the server, and the system says you were kicked by the server admin who set the limit.
Fixes:
Try a different server with players located closer to yourself.
Make sure there are not too many people using heavy downloads or streaming applications at your home or on the same network.
Sep 27, 2013 | Activision Call of Duty 4 Modern Warfare...
I have no problem connecting to web. My dgl-4500 shows all gaming ports timed out. Poor game performance.
Hi jwm5001,
As a fellow MMORPG player (am on WoW), i feel for you, esp if you pvp. I know what you're going through so allow me to offer some views on this. Try disabling all other gaming ports and only select the one that you are using. Also pls do the following (although you might know this already):
1. Click on Start, run
2. In the Run box enter this command: cmd
3. A small DOS black screen should have popped (this is known as a DOS Prompt screen). Enter these commands: Ping www.yahoo.com -t or alternatively, you could find out what the gateway address of the gaming site that you play is and try pinging that suing the "ping www.(address of gaming site here).com -t
4. The above command in 3 would signify your signal strength and also see if you're timing out when connecting to that particular site.
Overall, maybe it's just lag (server client lag) or a port based lag (for that MMORPG), or realyl crtappy intenet connectivity. General rule of thumb is:
Anything that times out, is bad
Anything that has a TTL of more than a normal range is bad
Anything that says destination host unreachable, is really bad!
So, yeah, try it out, lemme know any updates, stay cool aight?
I hope the above information helped. Please do let me know if there are other queires regarding this. Also, pls remeber to vote for me if you find this solution useful. Thank you.
Regards,
Technomancer
Apr 05, 2010 | D-Link DGL-4500 Wireless Router
I can recieve email but I cant send any email out
If you can successfully receive e?mail messages, but can't send messages, then Windows Mail is having problems connecting to the outgoing e?mail server that's used to send messages. These are likely possibilities:
  • If you've never been able to send e?mail successfully using Windows Mail, your e?mail account is probably not set up properly. First, follow the steps to verify your e?mail account information in the "I can't receive e?mail" section of this help topic. If you verify that your e?mail account information is entered properly, you might need to change your authentication settings so that when sending mail, you sign in using your e?mail user name and password. Check with your e?mail provider to see if it requires authentication for sending e?mail.
    To use authentication when sending e?mail
    1. Open Windows Mail by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, and then clicking Windows Mail.
    2. Click the Tools menu, and then click Accounts.
    3. Under Mail, click your e?mail account, and then click Properties.
    4. Click the Servers tab, and then, under Outgoing Mail Server, select the My server requires authentication check box.
    5. If the account information that you use to send e?mail is not the same information that you use to receive messages, click Settings, click Log on using, and then enter the user name and password that you use to send e?mail.
  • Many Internet service providers (ISPs) require you to be directly connected to their network to use their outgoing e?mail servers. If you're using a mobile PC and connect to the Internet using a different ISP (such as when using a wireless connection in a hotel), you might be able to receive, but not send, e?mail. Some ISPs will allow you to send e?mail when connected to a different provider if you use authentication when sending. Follow the previous steps to use authentication when sending e?mail. If your ISP doesn't allow this, you'll need to find out the name of the outgoing mail server for the ISP you're currently using, and then change the settings in Windows Mail to use it.
    To change the outgoing mail server settings
    4. Click the Servers tab, and then enter the new mail server in the Outgoing Mail (SMTP) box.
    5. If the new outgoing mail server requires authentication, under Outgoing Mail Server, select the My server requires authentication check box.
    6. Click Settings, click Log on using, and then enter the user name and password for the outgoing mail server.
Mar 27, 2010 | Yahoo Mail
Gprs, mms and inet seetings for se c510
GPRS Settings:
1. Go to Menu>Choose Settings. Press Left Navigation Key to go to Connectivity. Scroll Down and click Internet Settings
2. Choose Connect Using: and Add Data accounts. Enter the following parameters
Account type: PS data
APN: www.globe.com.ph
3. Save Account
4. Choose Options Menu by clicking the left soft key.
5. Choose Edit. Leave all the settings as default except Proxy Settings.
6. Go to Proxy Settings and Edit.
Proxy: On
Same for all servers: Off
Proxy servers: Multiple
7. Click Edit on Proxy servers. Choose HTTP.
Username: Blank
Password: Blank
Proxy address: 203.177.42.214
Port: 8080
8. Press Back four times
9. Press Select to choose myGlobe CONNECT as default account.
10. Press Save.
11. Go to Main Menu> Internet>Options>Advance. Press Left Navigation Key to go to Connectivity.
Connect using: MyGlobe CONNECT
Default Homepage
Address: http://www.globe.com.ph/globe.asp
12. Press Save
MMS:
1. Go to Menu>Messaging>Settings>Picture message
2. Go to MMS profile
3. Create New Profile.
MMS profile name: MyGlobe MMS
Message server: http://192.40.100.22:10021/mmsc
4. Choose Connect using: and Edit.
5. Choose Options Menu by clicking the left soft key.
6. Create New and enter the following parameters
APN: mms.globe.com.ph
7. Save Account
8. Choose Options Menu by clicking the left soft key.
9. Select Edit. Go to Proxy Settings and Edit.
Proxy: On
10. Click Edit on Proxy servers. Choose HTTP.
Username: Blank
Password: Blank
Port: 8080
11. Press back four times
Press Save. Select MyGlobe MMS as new MMS profile
Jul 14, 2009 | Lands Phones
Gunz login on ijji.com doesnt work
Well i clicked play live and it worked and it logged me on but when i go to connect to a server its not showing ANY SERVERS it only show's the connect and exit button
May 22, 2009 | Dk Multimedia I Love Math - 2nd (2071074)...
It show that my wifi is %100 connected but no server conection
Hi, there are 2 things you can try:-
After each check whether the internet is working:-
First
Start Internet Explorer, ignore page not found
Click Tools --> Internet Options
Click the Connections Tab
Click LAN Settings
Make sure the use proxy server at the bottom is not checked and that Automatically Detect Settings is checked
Second
Try Setting Static IP address, instructions here
http://www.howtofixanything.co.uk/howto-282.html
Feb 12, 2009 | Acer Aspire One PC Notebook
I cant delete my music from my mp3
May be you need to restart it mostly that is the problem.
Dec 27, 2008 | SanDisk Sansa m240 MP3 Player
Blutooth problem
you should be fine
most lag is caused by people on your network downloading stuff Eg:Limewire
so check to see if anyone is if they are not and you still experience lag
ring up your ISP they might be having problems with servers
please rate.
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Call Of Duty 4 freezing in Multiplayer online only
It's the Call of Duty 4 Servers from uploading the Map Pack. Their are alot of players That have downloaded it recently, and it is lagging their Servers. If you just wait a little bit, the problem should be fixed and all set to go.
Jul 11, 2008 | Microsoft Xbox 360 Console
Nba live08 lagging on-line
Try starting a game with people you know locally, if your ping between users is too high it will be perceived as lag. when the server catches up with you, your system misses the refresh cycle with the other players and it disconnects you. a more responsive internet helps. Also if you are at a NAT3 connection it can cause problems. check your internet settings and see what it says, there are many online guides to setting to a lower NAT.
Hope this helps.
Mar 28, 2008 | Sony Playstation 3 (PS3) Console
EA Sports FIFA 15 - Xbox One Logo
483 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
James Wishart
Tony
MegaByteMe
MegaByteMe
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
