Question about Pelco DX1000
How to solve my projector going standby in 30 second ?
    New Friend:
  • 3 Answers
You can also try "Standby Helper"if you have the occasional issue of the projecter going off ..u can created a task in task scheduler that runs with a 30 second delay on startup.
Posted on Dec 07, 2014
How can i reset the lamp timer ???? Typ of beamer: Sony VPL-FX51 E-Mail:francois.humbert-prince@vtg.admin.ch
Connect with power cord and turn the projector to the standby mode.
Press the following keys on the control panel in the following order for less than in five seconds each: RESET, LEFT arrow key and RIGHT arrow key and then ENTER.(showing in the picture below)
(NOTE projector must be in standby mode and keys pressed less than five seconds)
now press power/standby key to ON the projector and check lamp hoursgood_help_1.png
Jan 31, 2011 | Sony VPL-FX51 Multimedia Projector
The projector is going into standby mode 30% of the way into the presentation. This is not my projector so I'm guessing at the setup. Can you help. I'm using my laptop with a PowerPoint presentation,...
check the settings. sometimes there is a shut off timer if it isn't used for a specific amount of time. you can turn that setting off in the menu (if it has it). otherwise, it may be overheating and needs to be cleaned out with canned air.
Jan 13, 2010 | 3M MP 8730 Multimedia Projector
The projector switching off after 30 seconds
check the following :
1.does the lamp glow
2.do u get the connected image
3.if yes does the screen show temperature or overheat
4.if yes then one of the cooling fans do not work properly & hence the unit turns to standby & goes into protection
if no 1 does not happen, then check the lamp physically,it should not show melted or breakage.
if the lamp seems ok, then the ballast is defective!
Feb 08, 2009 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Projector problems
Hi David IB
I've had teh same experience with a BenQ MP720 ( just the XGA version of your Projector )
I queried this with BenQ Engineer in Dubai and he said that it sometimes works exactly like a short on the machine.
If I could give you a tip , If it happens again don't put back the metal cover of the Mainboard it solves the problem 100%
Nov 19, 2007 | Office Equipment & Supplies
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Pelco DX1000 Logo
63 people viewed this question
Top Pelco Televison & Video Experts
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
