Logic lcdhf512 swiches on and off when on standby
Power up and down
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 06, 2014
My logic tv it goes from standby to blue light when I turn it on but then goes back to standby again
hi sounds like power supply fault, could be capacitors or a mainboard thanks
shaun
May 20, 2017 | Televison & Video
3 time blink sony - Sony 40 KDL40EX520 LCD TV what is the problem
try a power reset first. 3 flashing light is bad main logic or power board ,check for standby volts if ok replace main logic board
May 14, 2017 | Sony Televison & Video
No standby power,tv is dead
check main lead,power swich & main line
May 28, 2015 | Televison & Video
Cant switch on my Irion TV
Maybe things will improve if you leave your TV permanently receiving power from the wall switch and do the actual on-off switching at the TV. Your Orion TV draws standby power even when it is off. When you flip the wall switch off there is no standby power
Jul 24, 2013 | Televison & Video
NEC LCD1760V shuts power down after 3seconds
Hi Ron usually power down issues are caused by faulty power supplies especially if the projector looses power completely however the logic board could be protecting itself if it detects a fault such as a fan not working either way it is not recommended that you try to fix it yourself unless you know what you are doing, but it may be worth removing the cover and checking that the fans are working and connected properly, occasionally the lamp can be at fault especially if it has been used for many hours if the projector tries to power up and you see light through the lens and then it looses power its probably the psu at fault, if it powers up then goes into standby of fault then its most likely a logic issue. I hope this helps Regards Ant
Nov 30, 2011 | NEC Office Equipment & Supplies
My sanyo tv model CE32LD81-B is currently on standby but i cant switch it on with or without a remote i think it may have been blocked
I think it has a power supply fault. The standby power supply is a small, separate supply from the main power supply.
I hope that helps.
Mar 10, 2011 | Televison & Video
Standby light is flashing and i acnnot turn the telly on. Whats the problem?
Issue with Power Innitial Logic Board Relay wont Clik On Due To Damage inside TV... Exemple.. Lamp Projection Burnt Out.. Overheat Component ... All TV Got a Automatic Security Power Off Swich It prevent serious damage insite TV..... Please Refer to a Certified TV Repair Your TV need to be fix ..good luck
Oct 07, 2010 | Televison & Video
No display on monithor cpu fun runs &but mobo led
do it only if u r a professional..
assuming that the system bios hs not been flashed or updated in a wrong way..if so u gotta replace the m/b..
1st see if the ram(s) is loose/faulty..open n resit it..
check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
if all above are ok..check the cmos/system battery..(above +3v)..
check the cpu fan rotating and the cpu generating heat..try replacing the cpu with a standby (if no heat is generated)..
there may b a chance for m/b's crystal clock generator to b faulty..try repairing or replacing the m/b with a standby..
there may b also problem with ur monitor or display adapter, try replacing with a standby..
hope it'll b enough to solve ur problem..
seek professional assistance of ur system admin/vendor....
Nov 03, 2009 | Intel D845GVSR Motherboard
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
