Question about Ovens
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
The oven heating element wasnt work but the grill working finne. I change the Oven element but the problem still occur. Another fuses blow and Oven elemennt dont work. I still canj used grill but when i turn for oven the fused go down again. I belive that its no heating element problem? What can be then?
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 98 Answers
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Posted on Dec 06, 2014
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
I have a Teka oven HI-595 that shows power, fan works and grill works but oven won't heat up. What should I do?
If the fan is working o/k, then it is probably the oven element that is faulty, usually located at the rear of the oven compartment behind a removeable cov er.
Oct 21, 2010 | Ovens
Teka h e 500 oven wont heat up....
If the fan is working o/k then the oven element is probably faulty, this should be at the rear of the oven behind a removeabkle cover.
Make sure you have the control set to grill , for grilling
Dec 03, 2009 | Ovens
I have a baumatic bc3510ss double oven. everything works fine except the large oven. you can turn on the grill or oven but when you turn on the temperature the rcb blows on the fuse box.
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Please rate my solution.
Thanks.
Nov 01, 2009 | Baumatic Ovens
Teka Model HC-595 - oven does not heat, fan working ok grill working ok
Sounds like the fan element has blown. I think access is from inside the oven at the back BUT the screws to undo the element are accessed by removing the rear cover. You will have to take the oven out of the cabinet to where is is fitted to do this and from memory there is an earth tag which is fixed to one of these screws
Oct 19, 2009 | Ovens
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Oven not working - fuse blown
Probably the oven element has gone .Disconnect element and try again if fuse does not blow, change element.
Plz rate this solution.
Thanks
Dec 14, 2008 | Smeg Ovens
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Ovens Logo
142 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
