My mirai tv takes long to turn on
When i switch on tv it is dead but if i leave it switched on it takes about ten minutes to come on
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 06, 2014
Cant remove key
Try the reset for the key switch , hook up battery charger or maintainer to battery then turn key on do not crank engine leave key in on position for ten minutes , repeat a total of three times then turn key switch to off position after third cycle then remove key . Then reinstall key to ignition switch then crank the engine over and see if that fixes your issue .
Jan 23, 2014 | 2000 GMC Jimmy
Sanyo ce42f switching off
Cooling fan might be the problem. Anyhow, the TV needs servicing.
Aug 21, 2012 | Sanyo Televison & Video
We bought a new ignition switch for the key not coming out of the ignition but when we installed the new switch the car wouldn't start...is there a step that we're missing? (2004 Aztek)
Hello: TRY THIS Attempt to start the car leave the key on for 10 minutes or until the security light goes out, at this time turn key off for 10 seconds, turn switch on for ten more minutes or when security light goes out, turn key off for 10 seconds. Turn key ON for ten minutes or when security light goes out, turn key off wait 10 seconds, then start car....
Jul 31, 2011 | 2004 Pontiac Aztek
Atn day/night vision had scope on for maybe five minutes and left batteries in with the switch in the off position in the morning the batterieswere dead,was told to take batteries out when not in use
Hello, You turn off the scope switch, hey. But did you turn off the IR switch? Never leave batteries in you NV devise. It creates lot of problems. Just take them out and wrap those batteries in plastic bag each and store them in cool dry place. stewbison
Dec 28, 2010 | Optics
Television keeps cutting out every half hour, have to take plug out for ten minutes for the television to start again, this is continual through out the day.
It would appear you have some dry solder joints probably in the power supply or high voltage area of your unit, is there any visual warning before it shuts down, flashing picture, distortion etc
Nov 03, 2010 | RCA Mirai T3715C 37 in. LCD TV
Cranks has fuel pressure and spark, no start just replaced ign switek for no spark problem 04 olds alero 3.4L
TRY THIS PROCEDURE WITH IGNITION ON WITH KEY IN SWITCH.LEAVE SWITCH ON POSITION WITH ENGINE OFF. FOR TEN MINUTES WATCH THE SECURITY LIGHT IF IT TURNS OFF IN TEN MINUTES.TURN OFF IGNITION SWITCH FOR 5 SECONDS THEN TRY STARTING DO THIS PROCEDURE TWICE.IF CAR DONT CRANK THE DEALERSHIP HAS TO REPROGRAM NEW KEY AND IGNITION SWITCH.
May 12, 2010 | 2004 Oldsmobile Alero
Truck wont start
Turn the key on and leave it on for ten minutes,then turn it off,and right back on,leave it on for ten minutes,then turn it off,and right back on for ten minutes,a total of three times,30 minutes.Then try and start the vehicle.
Apr 11, 2010 | 1999 Ford F350 Regular Cab
How do you star a 98 chavy malibu with tha anti theft light on
Here is what you do. make sure the battery is fully charged cause you dont want it to go dead during this process or it wont work. step down on your parking brake pedal and leave it down. this will keep the headlights off during the process so the battery wont go dead. turn the ignition key like you were going to start the car then leave the key in the on position. you have to leave the key in the on position for ten minutes. during the ten minutes you will see the anti theft or security light flashing or the display in the instrument cluster. when the ten minutes are up the security light will go out. once the light goes out attempt to start the car. if it doesnt start turn the key all the way back to the off position count to three then attempt to start the car then leave the key in the on position another ten minutes till the light stops flashing again. sometimes it takes up to three ten minute cycles to reset the antitheft system. so basically you do the same thing three times leaving the key in the on position for ten minutes each time so it will take approximately thirty minutes. sometimes it will work on the first try though.
Oct 31, 2009 | 1998 Chevrolet Malibu
I accidentally put the key to our second car half way into the ignition to our 2005 chevy suburban. I immediately took it out, but when I went to start it, the key will go in, but will absolutely not turn...
Yes. Turn your key to the on position and leave it. You will see the display flashing security in the instrument panel. leave the key in the on position for approximately ten minutes till the security light stops flashing. Then try to start it. If it does not start. Immediately turn the key back to the off position and turn it back to the on position and repeat the ten minute process. It may take up to three ten minute cycles to reprogram your key to the antitheft system. Make sure your battery doesnt go dead during the process or it will not work. To make your headlights stay off. press down on the parking brake pedal this will keep your headlights off while the key is on.
Oct 30, 2009 | 2005 Chevrolet Suburban
DVD player turns on; but apperently will NOT play the movie after we put it in... HELP!!!
I had the same issue and could have kicked myself in the ***! Make sure the AV slide switch is in the out position or it will not play at all. As soon as you switch from IN to OUT it will work properly.
May 02, 2009 | Memorex MVDP1088 Portable DVD Player with...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
