Question about Canon Image Class MF4270 Monochrome Laser Network-Ready Multifunction 21ppm Duplex Laser Printer, 2235B001AA
When printing uisng an mf4270 I get an error "load correct paper". I am using A4 and the setting is A4 on both printer setting as well as printing driver. My OS is Win7 and editing software MS office and OpenOffice. I also tried to reinstall but the problem remains the same. This also happens with my PDF. In all cases only the first page prints, the flashing light and bbeping sound goes off.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 884 Answers
Hi
Just a thought but is the printer detecting the "type" of paper you are trying to use, as opposed to simply the size. For example, is it trying to load "glossy photo paper" specified by the printer utility and finding standard photocopy paper.
Cheers
Posted on Dec 06, 2014
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
Sep 20, 2015 | Canon LBP2900
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Mar 31, 2011 | Office Equipment & Supplies
Connected with usb cable but error occured load correct paper
If you send a print job to the printer and get this error, check the page settings on the software you are using. The paper size does not match what is available. Most common error is Metric A4 as the default size.
Feb 23, 2011 | Office Equipment & Supplies
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Hi I have a Konica Minolta 2490MF and when I try to print a document/s it will print the first page only then comes up with an error 'incorrect paper size (1LT)' the paper size is correct (A4) and the...
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4 Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Nov 13, 2007 | Office Equipment & Supplies
Canon Image Class MF4270 Monochrome Laser Network-Ready Multifunction 21ppm Duplex Laser Printer, 2235B001AA Logo
78 people viewed this question
old marine
old marine
