Question about Philips HF3480 Wake-Up Light
Clock stays at the original set up time without moving on ... ?
Everything, clock just does not move on (eg if I set time on 09:15, it stays always on that time)
    Top Expert:
  • Philips Master
  • 75,581 Answers
Press the start button.
Posted on Dec 06, 2014
I cannot get my thermostat althc014 to turn down by its self when room tempreature is reached
How To
Set The Temperature
The reason the stat is coming on during the night/ always
being on is setting number 5, there are 5 settings on the Salus
is the time you want heating on eg, 07.00 and set the temp (20)
is the time you want it to go off eg, 10.00 and set the temp (10 this
will turn it off)
3 is the time to come on an evening eg. 17.00
4 is the time you want it to go off eg,
23.00 and set the temp (10 this will turn it off)
5 the problem
many people have is that they do not set number 5 correctly, this is a
night/ frost stat and if you don't set the time and temperature same as 4
ie, 23.00 and 10*c then the heating will stay on.
How To Set The Time and Date On Salus Programmer?
1.Press the
Set and Select buttons simultaneously to enter the clock setting mode.
2. By using
the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock.
Once selected press "SELECT".
3.The "HOUR"
will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the
desired time. Press "SELECT".
4.With the
"MINUTES" now flashing adjust with the arrow keys to the correct
minutes. Press "SELECT".
5.Now the
"YEAR" will need adjusting. Again use the arrow keys to change and press
"SELECT".
6.Now adjust
the "MONTH" with the arrow keys and press "SELECT"
7.Next to
change will be the "DAY OF THE MONTH" again with the arrow keys change
and press "SELECT"
8."dLS" will
now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF"
use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Hope this information is what you need to operate your unit.
Oct 01, 2013 | Computers & Internet
Need a manual for altech althc014. have no idea how to use it. can't work out how to just turn on without the timer!!
Ive been having the same problem! I found these instructions on a forum if it helps-
To Set the Temperature
The reason the stat is coming on during the night/ always being on is setting number 5, there are 5 settings on the Salus
1 is the time you want heating on eg, 07.00 and set the temp (20)
2 is the time you want it to go off eg, 10.00 and set the temp (10 this will turn it off)
3 is the time to come on an evening eg. 17.00 and set the temp (20)
4 is the time you want it to go off eg, 23.00 and set the temp (10 this will turn it off)
5 the problem many people have is that they do not set number 5 correctly, this is a night/ frost stat and if you don't set the time and temperature same as 4 ie, 23.00 and 10*c then the heating will stay on.
How do I set the time and date on my Salus programmer?
· Press the Set and Select buttons simultaneously to enter the clock setting mode.
· By using the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock. Once selected press "SELECT".
· The "HOUR" will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the desired time. Press "SELECT".
· With the "MINUTES" now flashing adjust with the arrow keys to the correct minutes. Press "SELECT".
· Now the "YEAR" will need adjusting. Again use the arrow keys to change and press "SELECT".
· Now adjust the "MONTH" with the arrow keys and press "SELECT"
· Next to change will be the "DAY OF THE MONTH" again with the arrow keys change and press "SELECT"
· "dLS" will now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF" use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Sep 27, 2010 | Heating & Cooling
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Jul 12, 2010 | Vacuums
How do I change the time on m Siemens Microwelle plus oven please? Model number HF75960GB
Did you try pushing the clock button, setting the time (eg. 300) for three o'clock, and then push the clock button once more. If this doesn't work, don't push the clock button at the end. Just set it, and let it stay until it stops blinking - and then it should be set. If you need further assistance, let me know and I'll help you. I'm just going by the usual standard of setting clocks on microwave's - but maybe with this model, there's another way. Good Luck to you! - Jim
Mar 28, 2010 | Siemens Microwave Ovens
Set clock
So just to sumarize--when you press the INFO Button and select ADJUST CLOCK, for this time of year --Winter--set Daylight Savings Time to OFF--that will immediatly move your clock back 1 hour. All that selection does is just toggle 1-hour ahead and back--but it doesn't automatically select when DST is in use. Then select AUTO ADJUST to ON and leave it there; this will make sure your clock is always locked to GPS and is always accurate.
Mar 14, 2010 | 2009 Lexus RX 350
How do you set the microwave clock?
After setting the time push the clock button again and it should start working after a minute passes (on some models you have to hit the start button after setting thr time!
Please rate this response
thank you!
Jan 26, 2009 | Microwave Ovens
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Philips HF3480 Wake-Up Light Logo
90 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
