Question about HP Office Equipment & Supplies
Is there a way to use just the HP scanner without going through the HP interface. I just want to use the scanner directly from the hpqscnvw.exe file in Windows 7/64. I was able to do this with no pr
I do not want to reinstall the HP software again as each time I do, the drive letter of the printer changes or I have to reinstate all of my settings and defaults. Or is there a reliable (Free) scanner program available that I could use instead? Thanks for any help or suggestions.
  • HP Master
  • 5,594 Answers
Use windows fax and scan already incorporated in windows 7!
Posted on Dec 06, 2014
I have HP7410. When I loaded to my laptop after desktop died, I keep getting HP Imaging device not found when I try to go into it to scan photo. Printer works. Laptop OS is VIsta
To scan a document using Windows Photo Gallery in Windows Vista, follow these steps:
  1. Click the Windows Vista (c01319360.gif ) icon, click All Programs , and then click Windows Photo Gallery .
  2. Click File , and then click Import From Camera or Scanner .
  3. Click Import , and then click Scan .
To scan a document using Paint in Windows Vista, follow these steps:
  1. Click the Windows Vista (c01319360.gif ) icon, click All Programs , click Accessories , and then click Paint .
  3. Make any desired setting changes, and then click Scan .
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube. The following scan options and file types are available when you scan with WIA drivers:
c02222409.gif If you experience an error during scanning, try these general scan troubleshooting steps (c02114802) (in English). Workaround Perform the following steps if you are unable to scan directly from HP Solution Center in Windows Vista.
  1. Click the Windows icon (c01319360.gif ), and then click Computer .
  2. Double-click Local Disc (C:) .
  3. Double-click Program Files .
  4. Double-click HP .
  5. Double-click Digital Imaging .
  6. Double-click Bin .
  7. Locate and double-click one of the following files. You will only have one to choose from.
    • Hpiscnapp.exe
    • Hpqscnvw.exe
    This will launch the HP Scan application.
  8. Select New Scan , and then change any desired settings to the scan.
  9. Click Accept to save the scan to the desired location.
Dec 27, 2010 | HP OfficeJet 7410 All-In-One InkJet...
No scan options
Did you install the full software before connecting the all-in-one to the computer? If the printer not scanning to the local computer or a networked computer? Were you trying to use the scanner buttons?
If this is a local problem (USB connection) uninstall any generic driver (these only drive the printer) and then unplug the data cable. Next download and install the software from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=439491& (select your OS from the list). Connect data cable when prompted to do so. Try a new data cable if the problems persist (scanners require bidirectional communication and will fail when the printer works).
Try a direct connection (no USB hub or print server).
If the computer failed to respond to scanner button press, make sure that the monitoring program is running. You also need to set up the scan destinations in the HP Solution Center for the buttons to work.
If the scanner program isn't running, you can launch them manually. Computer > Local Disc (C:) > Program Files > HP > Digital Imaging > Bin (double click on each of the above drives/folders). Find either Hpiscnapp.exe or Hpqscnvw.exe and double click to launch the HP scan program.
XP, Vista and Win7 can acquire scans without the HP software but the scanner buttons will not work. All three can acquire scans with Paint (File > Import from Scanner or Camera > New Scan). Vista and Win7 also have Windows Fax and Scan (New Scan).
Since you need to set the destinations, you should use the HP software to launch scans first. This lets you get a feel for the defaults that will be best to put into the destinations.
I hope this helps.
(If the unit is networked, I do not know how the software connects.)
Sep 09, 2010 | HP Photosmart 3310 Printer
My HP C5280 scanner is not picking up my computer. USB is connected and printing works fine, but the scanner isn't recognizing my cpu.
firstly check whether the copy is working or not if not follow the document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01152441&cc=us&lc=en&dlc=en&product=3204464
if it does make a copy
1.go to my computer
2.go to C:
3.go to program files
4.go to hp
5.go to digital imaging
6.go to bin
7.search for the file named hpqscnvw.exe and double click on it check whether you ca n scan from there or not if yes ............. uninstall and reinstall hp solution center and if it does not scan follow the steps below
8.uninstall and install the printer
this should work .....................................thank you
HAMID
Oct 20, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP c6180 scanner problems jun 2009
well go to c:\program files\hp\bin\hpqscnvw.exe
the scanning should be ready to go.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Jun 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP 1410v all-in-one scanner won't work
Please follow the steps given below to scan from other applications.
Windows XP:
Scanning from Microsoft Paint:
1. Click Start, click All Programs, click Accessories,
and then click Paint.
2. Click File and then click From Scanner or Camera.
If this option is not available, Please let me know.
3. If more than one image source is connected, select the
HP all-in-one product and click Next. The scanning software
will appear. Preview the image by selecting Preview,
or click "Scan" to scan the image directly into Paint.
4. The image will open in paint for editing and/or saving.
Using Windows Image Acquisition (WIA)
Verify that the all-in-one product power is turned on and the printer cable is properly connected.
1. Click Start.
2. Click Control panel.
3. Click Scanner and Camera Wizard.
Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If it is possible to scan from any of the above methods, try to scan from HP schortcut File and get back to me with the results.
Scan Shortcut:
1. Search for the file hpqscnvw.exe
2. File should be available in the following location
C:/Program files/HP/Digital Imaging/Bin folder
3. Create a shortcut on the desktop and double click the same
to activate the scanner and try scanning.
Windows Vista:
Scanning with Windows Photo Gallery
1. Click the Start ( ) icon.
2. Click All Programs
3. Click Windows Photo Gallery
4. Click File and then click Import From Scanner or Camera
5. Click Import
6. Click Scan
Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate,
Windows Vista Business, and Windows Vista Enterprise.
1. Click the Start () icon.
2. Click All Programs.
3. Click Windows Fax and Scanning.
4. Click New Scan.
5. Click File and then click Scan.
Scanning with Paint
1. Click Windows.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Scanning from Shortcut File
* Click on the Windows logo to access the start menu.
* Click on Computer.
* Double click on C:\drive icon.
* Double click on Program Files folder.
* Double click on Hewlett Packard or HP folder.
* Double click on Digital Imaging folder.
* Double click on the bin folder.
* Locate the hpqscnvw.exe file and double click on it.
Vishwanath V U
May 19, 2009 | HP PSC 1410v All-in-One Printer
HP Photosmart C3180 All in One - Scanner problems
if u have the solution center in ur desktop, right click on that... the go to properties then \click open file location... install/repair the "hpqtra08.exe" then look for "hpqscnvw.exe" right click on that then send to desktop, if u wan to scan just click on that icon on ur desktop the "hpqscnvw.exe
May 27, 2008 | HP Photosmart C3180 All-In-One InkJet...
Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
May 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
Communication error occurred with scanning component. Please advise on how to solve this problem.
First try to scan from the scanners and camera wizard in control panel to check the communication between the computer and the all-in-one. If we are able to scan fine from the control panel, then search for the scanning file hpqscnvw.exe and try to scan from there, if you are able or not able to scan from the scanning file, download the scan diagnostic utility from the HP website and run it and try to scan, if the issue persists reinstall the all-in-one software.
May 25, 2008 | HP Officejet 5610 All-In-One InkJet...
F380 hp all in one
This issue occurs if the scanning files are not installed properly. Once search for the hpqscnvw.exe file and try to scan from there and check for the result. If you are able to scan then download scan diagnostic utility from the hp.com and run it. If the issue persists reinstall the software.
May 20, 2008 | HP DeskJet F380 All-In-One Printer
Scanner won't work but the printer does
Ok here is the answer you have all been waiting for - look on the CD that came with any HP printer for the mac and you will see that it is for 10.3.9 and 10.4. I bet you dollars to donuts you have the new 10.5 leopard software and you got the new printer for free from the apple store.
All is not lost - go to the hp website at www.hp.com and on the left side you will see a grey menu that says software and driver downloads click on it and type your product. The version right now is 9.7.1 once you get all the way through. DO NOT INSTALL THE HP INSTALLER FILE - it is the same as the CD.
Well on the off chance your using windows the same applies - delete the old software on your computer and follow the steps above. The version number you will need depends on what OS but just make sure it is the most recent and you should be fine.
Jan 22, 2008 | HP PhotoSmart C4280 Laser Printer
Seeker5211
Seeker5211
