Question about Aiphone JF-2HD HANDS-FREE SUB MASTER FOR JF-2MED
Just Installed AIPHONE video intercom JF-2MD with Sub unit JF2HD worked perfectly.In the evening when I switched off the 2HD sub unit & switched on again now continuously all 4 LEDs are flashing c
Installed new Aiphone video intercom unit
2 Suggested Answers
  • 11800 Answers
SOURCE: On a aiphone C-ML, when
The system uses slight different frequencies for receiving and emitting - most likely you were unlucky enough to get a unit with the receiver frequency that has a mirror one occupied by a legit public station who doesn't filter it's harmonics correctly.
The dealer is correct, a simple LC filter on the receiver will eliminate the crosstalk and the radio station should fix it for you - contact them , explain the situation and ask them to either filter their emitter better of fix your unit.
Posted on Jul 21, 2011
Can I connect camera and monitor to existing aiphone Vc-6M intercom?
Aiphone intercom systems are very restricted in what you can and cannot connect. Also the type of functionality you require is determined by the master station that you have. With apartment system VC6M you will be able to configure very specific modules which can be viewed at this site and this is not much.
http://www.aiphone.net.au/vcm.htm
As the description suggests it is only meant to be a cost effective audio unit. (Video is available in apartment mode with the GT system)
http://www.aiphone.net.au/gt.htm
Sep 02, 2014 | Aiphone Da1ds Audio Intercom Door Station...
Friend with AVR 335 is experiencing very low subwoofer output to powered sub - has to be turned up to max for any sound at all and really just produces low rumble - no real impact - have tried sub with my...
Why aren't you looking at the sub for the reason? It may have the crossover set too high.
If the sub is loud enough during level setting, look at receiver settings, otherwise it's the sub amp.
Feb 10, 2011 | Harman Kardon AVR 335 Receiver
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
Kenwood KVT-512 subwoofer
put it in standby mode first.. then switch the rear av-out to sub.. then you can turn the sub on/off
Apr 04, 2009 | Kenwood KVT-512 Car DVD Player
Sub not working with amp
Connect a sub cable to the amps sub OUTPUT then to the sub input turn the volume up half way on the sub then go to the amp setup menu and make sure the sub is switched on then set the cross over to suit your speakers,if your not sure set to 80hrtz.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | Sony STR-DE475 Receiver
Sound shuts off, sub still works
That is a common problem with this radio, for it can not go to loud without going down in volume or shutting down.
Dec 08, 2007 | Pioneer DEH-P3100 CD Player
Sub now very quiet
It sounds like your sub may have died ,get hold of a mulitimeter and check the impedance it should be 2 or 4 oms depending on the sub.
Nov 02, 2007 | Car Audio & Video
Amp
I think it's a bad switch
Jul 07, 2007 | Pyle Blue Wave PLA2740 Car Audio Amplifier
Aiphone JF-2HD HANDS-FREE SUB MASTER FOR JF-2MED Logo
47 people viewed this question
Top Aiphone Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Aiphone Radio Communication Expert? Answer questions, earn points and help others
