Question about Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW
How to clear the display error on konica minolta c452
When switching on the machine konica minolta c452 displays document cannot be detected remove the document and then reposition correctly.
  • Konica Minolta Master
  • 6,161 Answers
Sir there is a lever in the rear of the machine when you lift the document feeder it is not jam or broke, also there is a small magnet and sensor in the front of the Doc feeder right side and the copier it self ensure the document feeder is properly aligned. Does this happen on the document feeder or on the big glass? Also mite want to have a technician run alignment & tray adjustment.
Posted on Jan 03, 2015
How to remove error c-3B02
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. Either of two parts bad the High Current Assemble or the Fuser GET A TECH OUT TO LOOK AT IT.
Procedure:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Mar 16, 2016 | Konica Minolta Bizhub C452 Copier
How to remove error c2257
DEEPAK, YOU NEED TOMORROW TO CALL MINOLTA CUSTOMER SUPPORT FOR PROPER WAY TO CLEAR THESE CODES!THAMKS
Jan 24, 2016 | Konica Minolta Bizhub C452 Copier
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta c 452 error code c 2161 & 2164
Hi
The descriptions for the two error codes you mention can be found at the two links below:
Error Codes Konica Minolta bizhub C452 Code C2164
Error Codes Konica Minolta bizhub C452 Code C2161
They would appear to be related to the same problem. For further information I think you would be best going to this page: Konica Minolta bizhub C452 Manual where there are many different manuals for this machine, which can be downloaded by clicking on the one you require and then following the instructions.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Konica Minolta Office Equipment & Supplies
What is Code C-3725 on Konica Minolta Bizhub c451
C3725 Fusing abnormally high
temperature detection
(NS sensor)
• The NC sensor continues to detect a temperature
higher than a predetermined one
for a predetermined period of time.
Procedure for resetting
4. Check to make sure that [OK] is displayed and the it has been reset.
Jul 17, 2014 | Konica Minolta bizhub Office Equipment &...
MINOLTA C452 KEEPS TURNING ITSELF OFF
what is display on the screen prior to turning off
Apr 08, 2014 | Konica Minolta Bizhub C452 Copier
Am konica monlta c452
C-2553 is Magenta image unit so replace the unit, as for the 0214 0215 no such codes for that model of machine
Feb 18, 2014 | Konica Minolta Bizhub C452 Color Copier...
I have a konica minolta c450 and it displayed error c-d 370. I cleared it using 0-7-1-3-9 as instructed but on switching on the machine,on the screen it asked me to enter serial number and call ser
Code is for NVRAM Data multiple errors, You need to have the machine Firmware updated, only available through Konica Minolta secure web site for dealerships and KMBS, You need a tech you can not find firmware on the internet Konica Minolta protects their copier operating systems
Feb 06, 2014 | Konica Minolta bizhub Office Equipment &...
per last, Code is for NVRAM Data multiple errors, You need to have the machine Firmware updated, only available through Konica Minolta secure web site for dealerships and KMBS, You need a tech you can not find firmware on the internet Konica Minolta protects their copier operating systems
I Have konica 7130 i can t Made L detection The
Code 0006 TCSB (toner control sensor board) output signal D/A conversion error To Clear SW2 (sub power switch) OFF/ON Problem Solutions, Replace 2? PRDB (printer drive board) 1? TCSB (toner control sensor board)
Aug 04, 2009 | Konica Minolta Di1610 Copier
Konica Minolta Bizhub C452 Color Copier, Printer, Scanner BRAND NEW Logo
160 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
