Question about Toshiba Televison & Video
Again i have a toshiba mod 65l7300v no pic or sound it comes on but wont power off need help
No pic no sound, but power on
Apparently power is getting to your TV but the internal power supply has failed
May 18, 2013 | Toshiba 55G300U TV
Toshiba 37HLX95 wont power on, just click sound. if i hold down power theirs a click as tho powering on and click again, but nothing, no pic no sound nothing. removed rear case cover and checked fuse, its...
I have the same problem. It happened once before about 4 years ago just after I bought it. I put a DVD in without the power on. I was able to take it out and it worked fine. This time my daughter put the DVD in, I took it out but still no picture or sound.
Have you had any luck?
Sep 11, 2009 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
We turned it off heard a noise and now the red power light just blinks and the power will not come on again. Toshiba TV Model #32SF62 Serial #11100308
what was the noise? POP!
If so then a capacitor on the power board has fried itself. Most problems where the lighyt blinks and nno pic or sound or a breif logo and then black are as a result of a faulty IC or capacitors on the control board
Sep 07, 2009 | Televison & Video
Toshiba DVD/HD Mod:#sd-H802A ''Cannot read high def dvd movies...
Hi there.
If it's just a case of you not being able to watch HD films, but you can watch normal dvd's, then it sounds like you need to reinstall your High Definition video codec.
What software are you using for your dvd playback?
Tim
Apr 22, 2009 | Computers & Internet
No pic no sound
sometime the overheated ic in the convergence section are the problem I have fix some
Jul 21, 2008 | Toshiba TZ50V51 50" Rear Projection...
No pic..or sound
a lot of times when a set is dropped the printed circuit board gets cracked, the only way to tell is to remove the back and printed circuit board and check; if not too badly damaged can be 'hard wired' across breaks and fixed
May 08, 2008 | Toshiba 36A61 36" TV
Toshiba tv mod tp55h60
Is this set a tp55 projection or a 36a40 direct view? If projection, these sets are bad with convergence problem. Meaning the color goes haywire, red, green blue are all misalign. If this was not what you experienced then it also could be a sound problem or vertical. Either way if you press power and will not come on it's tell you that there is a problem that needs to be address.
Sep 16, 2007 | Toshiba 36A40 36" TV
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Jul 23, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Kicker DX350
it sounds like you pop the power Reg. transistor or one of the Amp. chips instide. Some Amps has a pic fuse inside on the main board its green very small shape like a tear drop with a wire comeing out both ends it would in a socket some times white or black.
Sep 22, 2006 | Kicker DX350 Car Audio Amplifier
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
