Question about Chevrolet 2000 Chevrolet Blazer S10/jimmy S15 Chassis Brain Box
What nis it when you driving and my truck start wobbling
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
Control arm bushings
Posted on Dec 06, 2014
86 suburban sometimes wobbles really bad stops when i slow down what causes that
Sounds like warped rotors that are siezing up due to your calipers sticking.
Jan 25, 2013 | 1986 Chevrolet Suburban
Tip
Tire wobbles when driving? Check this explanation why it does that
While driving you start to slow down and it feels like a tire is loose and wobbling? That is caused by a broken steel belt in the tire. You will need to replace the tire ASAP!! The tires with broken belts expolde at high driving speeds which is very dangerous
on Apr 10, 2010 | Chevrolet 1500 Cars & Trucks
Steering wheel wobbles when driving 1995 eagle summit
Possibilities: wheel out of balance, bad ball joint, bad tie rod end, wheel bearings, CV-joint, bad tire, bent rim.
Nov 15, 2012 | 1995 Eagle Summit
Front Left side wobbly and there is a squeeky noise when driving
Have you checked the tires ?
Sometimes a wobble can be a broken belt inside the tire tread.
Or it could be something loose in the hub.
You could also switch the front and rear tire to see if the wobble moves.
Aug 07, 2012 | Cadillac Cars & Trucks
Front end wobble at higher speed nothing wrong with tierods everything seems tight jacked it up bushings bearings fine does not push or pull under 90 km and lower just out of the blue it will start to...
When a steering stabilizer goes bad, it will produce the exact wobble you have described. The one where you NEED to slow down to stop it, and then its fine. Its called "Death Wobble" in the car/truck enthusiast world.
Have you checked that? Typically called a steering stabilizer / steering dampener.
Jul 14, 2010 | 1991 Mercedes-Benz E-Class
Car died when driving it now wont start at car
If the chain broke yes the cam will not turn, only the crank will causing the fast spin
Feb 04, 2010 | 1995 Nissan Maxima
Car started to shake while driving
Jack front end. Use both hands to check driver and passenger side tires for slight wobble. If wobbles, you have a bad ball joint. Otherwise inspect tie-rod end for wear.
Oct 21, 2009 | 2000 Mazda 626
WOBBLE IN STEERING WHEEL
Hi
Possibly weak shocker / shockers?
Are they the original set ?
If so replace both.
Good Luck !
John.
Jan 20, 2009 | 2005 Chevrolet Silverado
NIS 2009 upgrade
I was able to uninstall NIS 2009 and Re install NIS 2008 without my initial settings being affected, which is what I was concerned with when I contacted you guys.
Nov 15, 2008 | Norton Internet Security 2005...
Chevrolet 2000 Chevrolet Blazer S10/jimmy S15 Chassis Brain Box Logo
42 people viewed this question
Top Chevrolet GPS Experts
Tom hale
 Russ Hill
Russ Hill
Are you a Chevrolet GPS Expert? Answer questions, earn points and help others
