Question about Sony VAIO SVS15116FXB 15.5" Windows 7 Home Premium 64-Bit Notebook
I got the damm over My sony Vaio S series laptop, I'v cleaned several times, but it is shown again, (my building is so old), how can I clean the damm forever?
My building is quite older (almost 60 years), all around the building has dame and dusts.
  • Bruce Gilbert Dec 27, 2014
    Hi Maq Drew, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? ????Do you mean DAMP????i.e.: water condensation on the laptop? If so, maybe try storing laptop in, protective pouch, in hot-water cylinder cabinet...? ...or somewhere relatively warm & dry...between uses.? GBU!
  • 4 Answers
A dryer is definitely a good idea.. you may also try using UD40 contact cleaner this will quickly help resolve the contact burst issue and save your motherboard/keyboard.
Posted on Jan 11, 2015
  • 24 Answers
Best way I have found to dry out a computer is to use a hair dryer on the lowest setting or no heat and blow it carefully into the vents on the laptop. I have done this successfully on Toshiba and VAIO laptops I used on my boat. Just be careful not to get the hair dryer too close to any plastic to avoid melt damage but on lowest heat or no heat setting that should not be a big issue.
Posted on Jan 10, 2015
Sony Vaio EB Series Fan Noise
I reccomend going to youtube to look for a walkthrough. When you get to the fan, gently brush it.
Jan 06, 2013 | Sony VAIO EB Series White Notebook...
Hi my dvd drive does not work properly. sometimes it can detect a CD or DVD but many times it can not. for example if it can not detect a cd when I eject and insert it again or after several times it...
Recognising a CD /DVD by DVD drive is related to the lense condition.
You try to clean the lense with cleaner CD which is available in the market.
If the problem still not solve then you change the drive
May 02, 2011 | Sony Vaio VGN FE890 Laptop Universal AC...
My laptop Sony Vaio CS 320J is shutting down with out any notice(not proper shut down but poweroff while running) and not booting again for @ least 2 mins. recently this issue started and this is...
Remove the bottom pan to expose the cooling fan, clean all dirt out of the heat sink and fins,and clean fan, next remove the heat sink to expose the processor ic, remove the old thermal grease with rubbing alcohol, and apply fresh thermal conductive compound to the heat sink and processor, "not to much! just enough to cover the critical areas and assemble. In most cases this will solve the shutdown problem.
Apr 15, 2011 | Sony VAIO VGN-CS320J Notebook
How to reset bios password on sony vaio laptop?
Please open you vaio laptop from bellow instruction link.
http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
Follow step 14
You can manege the idea about CMOS battery.
http://www.insidemylaptop.com/disassemble-sony-vaio-vgn-bx-series-laptop/
Follow step 11
But this is your actual model
http://www.insidemylaptop.com/?s=PCG-K33+PC+Notebook
Just remove the Cmos battery And wit 2 minutes again fit the battery .Your password will be soon reset.
Hope it will help you.
Dec 26, 2010 | Sony VAIO PCG-K33 Notebook
I have a sony vaio CS series , Flickiring screen
try to restart in safe mode by tapping f8 while restarting the computer
Select safe mode and select "safe mode"
Jul 29, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Sony Vaio K33; the fan seems to run all of the time, hot and nois
i had the same problem with my vaio.
when disassembling the notebook: after you remove the metal cover under the keyboard, you'll see three areas covered with black thermal tape. peel back the thermal tape and you should see tightly packed dust buildups in those areas. use a q-tip and vacuum if you can or air duster. be sure to clean the fans as well as the heatsink assembly.
once that is done, your noise level should be reduced by about 60-70%.
if you're still running hot, consider cleaning the old thermal grease off your processor and reapplying a new layer.
Apr 01, 2010 | Sony VAIO PCG-K33 Notebook
I recently had my Sony VAIO cleaned and consequently lost several programmes. Due to this, I cannot use the built-in camera, motion eye, and so was wondering where I could find genuine software which would...
You can find the drivers and supporting software regarding on the Sony Support Website
But you need to be ready with the model number and some merchandising details.
Jan 20, 2010 | Sony VAIO VGN-FJ270/B Notebook
Unhappy fan noise vaio pcg 3c1m
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
Never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Nov 23, 2009 | Sony Computers & Internet
3 month old Sony Vaio notebook keeps turning off by itself, won't even last more then a couple seconds to a couple minutes, tried system restore and defragmenting, and disk cleaning...still nothing!! could...
Try on the BIOS/System Setup and check if its turning off there as well. To entere there, start your computer up, and when you see the Vaio logo press [Delete] several times. You will see a blue screen or black with information of your computer, leave it there for as long as it takes to shut down, if it doesn't then please let us know.
May 04, 2009 | Sony VAIO PCG-K35 Notebook
Sony VAIO SVS15116FXB 15.5" Windows 7 Home Premium 64-Bit Notebook Logo
80 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
