Question about Cell Phones
What do i do with the unauthorised certificate?
Where do i go to restore my lost matric certificate
Certification Services - Department of Basic Education
www.education.gov.za/Informationfor/CertificationServices.aspx
  1. Cached
A change to an original certificate will not be considered unless the original certificate (not replacement) is returned. To change your name on your matric ...
Replace matric certificate ' South African Government
www.gov.za/node/727532
  1. Cached
  2. Similar
Apply for replacement of your matric certificate at the Department of Basic Education if you have lost or damaged your original matric certificate. You can request ...
Career Planet » Where can I get a replacement matric certificate?
www.careerplanet.co.za/where-can-i-get-a-replacement-matric-certificate
  1. Cached
  2. Similar
I lost my matric certificate. I damaged my matric ... Replacement (re-issue) matric certificate? I need a new ... (2) I damaged my matric certificate! What must I do?
Youth Village How To Recover A Lost Or Damaged Matric Certificate ...
www.youthvillage.co.za/.../heres-how-to-recover-your-matric-certificate-after-losing-i...
  1. Cached
Nov 26, 2015 - Please note: Applying for your lost or damaged matric certificate might differ from one province to another. Below is a guide to applying for ... restore my lost matric certificate Google Search
Jan 04, 2017 | Office Equipment & Supplies
Are There Any Fees When I Apply For A Business Loan?
The interest rate you will pay on your Business overdraft is linked to the Bank of England Bank Rate, which may change from time to time.
Based on our assessment of your individual circumstances, we may offer you a rate of 10.31% per annum (10.06% plus the current Bank of England Bank Rate). This is correct as at 4th August 2016.
If it is not prearranged, the Unauthorised Borrowing Interest rate is 26.4%.
The unauthorised borrowing interest rate has been effective from 01/08/2005 and was last reviewed on 09/03/2009.
The Unauthorised Borrowing interest rate is not linked to the Bank of England Bank Rate and can be changed by the bank at any time. In accordance to account terms and conditions, notice will be provided for changes to the unauthorised borrowing interest rate.
You'll pay an arrangement fee of up to 1.5% on your overdraft, which is related to the amount you borrow. We'll also discuss the terms with you before any overdraft is taken out.
To cover our administration costs for smaller facilities, there will be a minimum scale charge of between £100 and £250 resulting in the overall charge being more than 1.5%.
Aug 16, 2016 | The Computers & Internet
Why were more than 12 unauthorised transactions on my PayPal account?
login to paypal
In summary tab at bottom of page left side you will find resolution centre link
Here's how to report unauthorised transactions:
  1. Log in to your PayPal account.
  2. Click Resolve a problem in our Resolution Centre near the bottom of the page.
  3. Click Report a problem.
  4. Select the transaction you want to dispute and click Continue.
  5. Select "Unauthorised transaction" then click Continue.
  6. Follow the instructions.
Feb 22, 2016 | PayPal Computers & Internet
How to protect pro duo card from unauthorised viewing
you enter card into computer and and going card properties,there having security system.
Mar 24, 2013 | Sony 4GB Memory Stick PRO Duo Memory Card
I couldnt choose Citroen in the option so please discard the audit etc. I have a CITROEN C2 VTS (NU57 XSG) and have replaced the original headlights with Citroen (morette) twin headlights, i am wanting a...
loop the main beam to the second light simple ,find the feed with a meter when the main beam is on ,simple to do but be warned here ---make sure the light has a certificate of homoglonation and a E number in the headlight glass or you could face a big fine for unauthorised modification of a motor vehicle ,also this sort of work can only be signed off by a authorised garage with a Value Added Tax certificate and a inspection to change the cars papers at the local car testing station ,or dont drive in spain as they will impound the vehicle
May 06, 2011 | Audi TT Cars & Trucks
How to install ssl certificate on ACS 32
Installation of a certificate on Cisco ACS Note: ACS only supports PKCS12 certificates. Before installing a certificate, ensure that the certificate is of this type.
To install a signed certificate: Step 1: Choose System Administration > Server Management > Certificate.
The Certificate page appears.
Step 2: Click Install Certificate.
Step 3: On the Install Certificate page, enter values for:
• Server Certificate Format
This is a display-only field, and displays the PKCS12 certificate type.
• Server Certificate File
Enter the path to the local directory in which you saved the certificate file; optionally, click Browse.
• Private Key Password
Enter the private password key, which can be up to 32 characters.
• Confirm Private Key Password
Confirm the private key password.
Step 4: Click Install.
Step 5: To activate the certificate, you must restart all the processes on the ACS View server.
To restart the server from the:
•GUI-Choose System Administration > System Reports > Process Status, and click Restart ACS View Server.
•CLI-Access the CLI in the EXEC mode, and run these commands:
-process stop all
-process start all
regardsSandeep
Mar 08, 2011 | Avocent Cyclades® ACS32 (ATP0156) Server
1,8 sedan Can 16 inches wheel have offset 55 (same
No you cant because this vehicle doesnt have homoglonation certificate for this size wheel you can only fit what is specified by the manufacturer on technical certificate of construction and use of a motor vehicle .To use unauthorised modifications can result in the vehicle being impounded then crushed and driving ban and a hefty fine
Aug 12, 2009 | 2009 Honda Civic
When i apply themes in my nokia 3110c it shows that unable to open theme corrupted
Those themes will be either from an unauthorised source or having an expired certificate.Please do not install such themes on your device as it will contain viruses which may be harmful to your phone.So remove it from your phone as soon as possible.The themes which are not supported by your phone will also show a corrupted message.
Jun 27, 2009 | Nokia Cell Phones
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
