I have a Maytag Neptune. Everytime i go to do laundry i have to spin 1st. Because there is water in the drum everything else works just fine. Why does it leak in the drum.
    Habit-Forming:
  • 102 Answers
Water can only come from one of three sources: 1) water added via wet clothes between cycles (unlikely), 2) water backing up from the house drain into the tub (again, unlikely unless there is a plumbing problem and the drain hose is clamped - sealed to the house drain), 3) one of the inlet valves is leaking. Assuming number 3 is the source, you can easily determine which valve by pumping out the water and turning off one of the water valves at the wall shut off. In the morning look for water in the tub - if none, you've located the problem. If there's still water then repeat with the other wall shut off valve. In either case the inlet valve assembly (which inlcudes both hot and cold valves) should be replaced. It's just interesting to know which one caused the trouble.
Posted on Dec 06, 2014
Amigaman
  • 248 Answers
SOURCE: Washer will not drain properly.
The splashing you hear is a liquid thats in the balance ring. This is located at the front edge of the inner tub that you spun by hand. It helps balance the loads. This is normal. The smell is a problem inherent to front loaders. About once a month run hot water wash with a cup of bleach in it, no clothes. Best bet is to leave door open to allow air to dry interior. I removed bulb in mine.
Posted on Oct 06, 2007
IFIXALL
  • 868 Answers
SOURCE: maytag neptune mah4000aww won't spin.
Replace the control board and wax motor
Posted on May 24, 2008
SOURCE: maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Posted on Aug 20, 2008
SOURCE: Maytag Neptune Max Extract Quit Working
More information about the problem is needed...there are two levels of spinning..."regular" and "Max Extract" The Max setting spins the tub much faster. If you are having trouble with really wet clothes being left in the washer...haven't really been spun at all...this might have a couple of solutions. First, check the "out of balance" switch (a little plastic square with two green wires attached) located at the base of the tub on the front on my stacked unit. Because of the vibration in the tub, the wires on mine have broken twice.right at the switch. The other possibility is the main circuit board. Check out the internet for solutions/replacements.
My washer's Max setting is not working...and I don't know the reason for this...any help? Thanks...
Posted on Oct 18, 2009
  • 3 Answers
SOURCE: my maytag neptune front load washer won't spin all the water out
My Maytag Neptune MAH5500B or MAH5500BWW wouldn't spin either. It would go all the way through the wash cycle, agitation and all, as mentioned before, the spin cycle would start at the 9 minute mark, and get down to the 7 minutes then drop directly to 0 with no spin at all.
After hours of investigation it turned out the balance load switch was corroded. This switch is accessible through the front panel of the washer. The door must be removed and the front panel comes off, this switch is directly under the wash drum where there is a little electrical plug and switch which rests on top of stabilizer styrofoam. The connection was being made but there was green corrosion, and evidently the switch box was corroded within. When bypassed, the washer spun perfectly.
Hope this helps someone else out there - I was horrified to think that this washer would end up more landfill as it wouldn't be worthwhile to pay hundreds for a new motor control board as had been suggested was the problem.
Posted on Jan 18, 2010
Hi! I have a Maytag Neptune front loading washer machine. On a few occasions I have found a small amount of water in the drum before starting my weekly laundry. Today when I went to start my laundry...
This is symptomatic of a water control valve not closing completely- its no power/fail position is closed.
Whichever it is, hot or cold, needs replacing!
Service call ;-0(
Good luck,
John C
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
I heard my Maytag Neptune shake hard today when a load of laundry was going. I assumed the spin cyle got got offline for a second. The washer seemed fine. Then I did another load of laundry. While it...
do NOT call the Blue guys from Sears,,,he told me it would cost more than $2000 to fix a machine that will wash but not spin or drain ( I could get it to do both by pushing certain buttons). It is now outside and I have a used $215 washer that is doing great.
Nov 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition...
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Removed both water pump hoses, No blockages drum still has water init. Is this normal? Won't drain and go to final spin. Pump clean and spins free. Maytag Neptune MAH5500B
Water pressure switch adjustment or clogged. Check the small connecting hose to the switch body.
Final spin command signal generates from this part only.
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
