Fan does not stop - Heating & Cooling
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The assumption is that you are talking about the indoor fan....If so, check the thermostat fan 'on-auto' position and make sure it is in the automatic mode. If so, there is a possibility that the fan relay on the fan control is stuck in the closed position. If you have an older electric furnace, the first stage heating element could be stuck closed because the fan comes on with the first stage heat on many of the brands over 10 years old.
Posted on Dec 07, 2014
Central air unit (the outside unit) works fine then fan stops and makes a buzzing or no noise at all, later works fine again then again fan stops
I would start by testing or replacing the blower motor resistor, it's located next to fan, fan wires goto it. When fan stops try tapping on it. The resistor is more common than the fan
Aug 22, 2013 | 2003 GMC Envoy
My 2006 PT cruiser non-turbo has 34,000 miles. The A/C fan stops blowing only when driving long distance on a hot day. The A/C works fine driving around town and stop and go, but 30 minutes or longer...
The fan assembly has two speeds. Hi and low. There are two relays that control the fan and it is not uncommon for them to fail. I usually change fans and relays to fix that problem. Try starting your car and let it idle with the hood open. Turn the ac on. watch the fans and see how long it takes for fans to stop. Using a test ;light you would check if power going to fan plug. If fan stops while testing, check and see if power at fan plug. If there is power, the problem deals with the control side of the system, but if there is power there and the fan is not running it is a bad fan or relay
Nov 12, 2017 | 2006 Chrysler PT Cruiser
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
The fan stops running
check whether the power saver mode is on. put it off. or some timer must be on. stop the times. it wll be rectified
Jul 27, 2009 | Heating & Cooling
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
Jul 11, 2009 | House Brand Dryers
Fan won't stop on Maytag M1010
Some thermostats have a fan switch that turns the fan on to run continously. Check to make sure the fan switch is not turned on.
If thermostat is not the problem, then somebody will have to troubleshoot the control wiring to find the reason for the fan issue
May 02, 2009 | Heating & Cooling
FREEZER FAN HOWELS AND STARTS AND STOP STARTS AND
Your freezer fan will need to be replaced to keep it from stopping. Try to find the complete model number so I can help you fix and or replace the fan. Let me know, Thanks, Sea Breeze
Mar 21, 2009 | GE Freezers
2001 Solara fans run all the time after radiator installation.
the thermostat should be located inside the fan shroud it will be a small silver rectangular box usually @1/2" x 2" with a wire coming off of it (most models NOTE:if check engine light is on it will probably be the temp sending unit located elsewhere) however I would try to find a relay with the same numbers on it as the third one you pulled and swap the two then see if the fans stop and you will know if the relay is bad
Dec 30, 2008 | 2001 Toyota Camry Solara
Fan stopped
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
