Question about Ovens
How do I remove and replace oven door
We got it off to clean can't get the door back again
  • 3,963 Answers
Usually oven doors have to be lifted and two arms on the door drops into a hole on each side of bottom of oven.
Posted on Dec 06, 2014
MY self cleaning oven door will not unlock. Have tried to reset it. But it won't release
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Now if this has not worked then you will have to remove the top part of the oven to get to the latch asy which means you may have to remove part of the back of the oven or the entire back piece depending on your model to be able to remove the screws that hold in the top of the oven on the back then you should be able to see the latch mechanism
Now remove it and have it tested or simply replace it ok
Hope this helps please keep me informed on how this is going i can send you a link to a site that has a video on how this is done if needed ok to help you repair this
Best regards Mike
Nov 16, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
We have a Kenmore double oven. Awhile back something spilled as it was being removed from the top oven, and spilled onto the door of the lower oven. Now the glass inside the lower oven door is streaked and...
Please follow the below steps
1)Open the door.
2)Check the hinges and let the door be opened in half way.
3)Use Philips screw head at hinges screws.
4)remove the door and take the inner part alone.
5)Just follow the picture for more help.
Clean it and place it again.
It is very simple you can easily clean it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 07, 2011 | Ovens
Cleaning over but lock light will not goff and i can not open my oven
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 20, 2009 | GE JKP15 Electric Single Oven
Door locked after shutting down cleaning cycle earlier than
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning oven door won't open
May 15, 2009 | Ovens
Whilpool Double Electric Oven has NO POWER
I had the same problem the first time I used the cleaning cycle. The oven was under warranty when it occurred so I watched the repairman when he fixed it. He not only installed a larger fan, but he had to replace a thermocouple that is on the back of the oven, part number 4450934. The oven seems to die (lose power) after every cleaning cycle. I'm now ordering my third thermocouple. To replace the part, you have to pull the oven out from the wall to access the back. To do that, open the oven door. (If your door is locked because of the cleaning cycle, you may have to take a hacksaw blade to slip it in to see if you can trip the latch. The repair man was lucky when he did mine as the door clicked open when he was just messing with it so I don't know any trick to get it unlocked. He said that because the thermocouple died, it didn't provide the signal to unlatch the door, so the oven thinks it's still at 500 degrees and keeps the door locked which is part of the safety process). If you do get the door open, on the sides of the oven itself, at the bottom inside hinge of the door, you will see a screw holding the molding (frames the side of the opening of the stove). Remove each screw (left side and right side at the bottom) and pull the molding off. You now have access to the screws that hold the oven to the cabinet that it is sitting in. Remove those screws (mine has one on each side) and you can then slide the oven out. It's heavy so you will need help or have some thing you can slide it on to. It needs to come out far enough so you can access the back. You will see the thermocouple on the back, held on with two screws. Remove the wires and take the part off and throw it away (or keep it so you know what to order again next time as you will be replacing it again after you do another cleaning cycle) GREAT WHIRLPOOL PRODUCT. Reverse the process and you will be baking in no time.
I
Nov 03, 2008 | Whirlpool RBS305PD Electric Single Oven
Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Jan 02, 2008 | Maytag CWE5800A Electric Double Oven
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Cleaning the inside of the glass on the oven door
dont try you will broke something and then gonna think that was better to have a little dirt in there, a tech could do but whats if it comes again....good luck if you insist post back
Aug 07, 2006 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
