Question about Stanley Bostitch Ehf1838k Engineered Hardwood Flooring Stapler
Still an issue with shooting staples. the gun just clicks
Removed the top cover to clear the piston and the rear cap and it is clear. The number no longer sticks but shot 1 staple and then just a click
Have you been oiling it regularly? Compressed air is very moist so a few drops oil oil in the unit is needed every once in a while to lubricate it properly, try and see what happens.
Posted on Feb 27, 2015
2 Suggested Answers
  • 21 Answers
SOURCE: My bostitch compressor staple gun
I ran into the same problem. The way to repair the problem is to disassemble the gun. Start by removing te top of the gun where the exhaust comes out. Under the cap is where the piston is. You need to clean out the cylinder and the piston. Second you need toi take the rear cover off were your air hose connects. Look inside to make sure the inside is clear and clean. Also inside the cap where the exhaust comes out there is a spring loaded piece that is white in color. Make sure it is clean and also clean out the inside of the cap. After I did all that my stapler worked fine. Good luck.
Posted on Feb 03, 2013
After ejecting five staples, my staple gun stopped pulling staples into the feed and ejecting them. It makes the shooting sound, but nothing comes out. I examined it for staple jam, but found nothing.
staple guns are feed from the rear by a spring. check and see that the spring is still douing its job. if this isa air feed,inpact gunn, clean ejector ports and staple slide.
Apr 26, 2017 | Staples Tools & Hardware - Others
CraftRight 3 in 1 Staple Gun
See that shiny steel saddle-looking clip at the "rear" (under your palm when you're using the gun) next to the bottom? Push it inward then down to unlatch it, then pull it straight out. Insert 12mm staples, push that thing back in and latch it again. It SHOULD be a little hard to push it - the long spring is what feeds staples up to the punch piston at the front.
Aug 07, 2014 | Tools & Hardware - Others
I have rebuilt my staple gun all new seals new piston and driver blade new bumper cushen when gun shoots the blade wont retract up all the way you have to open the staple mag. fire the gun then the blade...
Inside the cap, there's a plastic circular insert. It's a common mistake to reassemble the gun with this cap spacer upside down, resulting in the top of the cylinder not sealing in the air that returns the piston. Simply undo the cap, turn the spacer over and screw it back on again. Done.
Feb 27, 2011 | Fasco Tools & Hardware - Others
Cant load staples t50 bn electric
There is a latch at the rear bottom of the gun at the back end of the chrome slider. Push it in a little enough to clear the little metal tab at the top of the latch and the pull the slider all the way out. This will give you access to the channel where you load the staples into.
Feb 25, 2011 | Tools & Hardware - Others
My bostitch compressor staple gun is not working. The compressor itself works fine, the other two guns work, but the staple gun-when you depress the safety and pull the trigger, the air comes out from...
If its the stapler I believe it is (SX1838) it has a broken driver. These staplers have a factory flaw in them, the drivers are faulty. Bostitch has since repaired the problem from the factory but their are still nailers out there that have this problem. Sounds like you have one of them, its an easy 5 min fix but you need to go to a Bostitch cervice center in your area and get a fresh driver installed. Your stapler has a 7 years warranty so it won't cost you anything. As a Bostitch service center I have done hundreds of those staplers, once the driver is changed ou shouldn't have this problem anymore.
Jan 04, 2011 | Stanley Air Tools & Compressors
Just purchased t27 arrow staple gun but can't load staples. I have removed spring loader from rear and unsuccessfully trying to load staples from rear. Wrong method? Wrong size staples?
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Aug 24, 2010 | Arrow Fastener T27 Light Duty Household...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Has staples loaded but does not shoot staple. I pulled out the follower and cannot tell if there is a jam, but looking at the "output" of the stapler seems to have a staple...
I think you just answered your own question. I have had one single staple stuck at the "output" where the staple shoot out and it drove me insane for a few until I slowed my roll, took a deep breath and said, I have got to be smarter than a piece of metal here, and took a calm slow looksy. Sure enough, it was one loan staple causing a backup of the rest. I have also had issues with overloading staples which eventually makes the spring pushup rod become less forceful as it pushes the staples up for firing. Not an issue until you get towards the last dozen staples or so, which can also lead to the last staple not quite getting that millimeter push ahead, to shoot out correctly. These staple guns are like babies. Have to treat them nice and pamper them and heaven forbid you ever drop that stapler cause if dropped more than likely it will never quite be the same again. Telecom Tech 16 years.
Jun 17, 2009 | Arrow T25 Staple Gun
(DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Jun 06, 2009 | Staples Tools & Hardware - Others
Senco narrow crown Stapler Piston will not go back
There is a spring and piston in the back cap of the nailer, this must be free moving and not sticking. If it is sticking it will cause the problem you discribed. If that looks ok you probably should install an o-ring kit and that should solve the problem. A Senco service center will carry the proper parts.
Apr 09, 2009 | Tools & Hardware - Others
Stanley Bostitch Ehf1838k Engineered Hardwood Flooring Stapler Logo
79 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
