Question about Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz
I have samsung LN46D6000Sf will not come on No Lights are on when pluged up
It has no lights on when plugged up it wont power on
  • Samsung Master
  • 3,382 Answers
This sounds like an internal electronic failure. If you are lucky it may still have some warranty. Check with the place you purchased it, they may be able to warrant it or repair it. This is not a DIY project unless you have the equipment necessary to do the repair.
Posted on Dec 06, 2014
My packard acer wont turn , power light comes on when pluged it , but wont power up
Packard Bell, Acer? Which manufacturer? Remove the power, remove the battery, remove hdd and RAM. Plug in the power supply and press On. It will complain that is has not any RAM etc. If it does, insert one RAM chip and try again gradually if not you have a motherboard issue.
Oct 05, 2016 | Acer Computers & Internet
When tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Oct 13, 2015 | Televison & Video
Interior wall panel battery lights does not lightup when 120 power is not pluged
The lights run off of 12V DC and use your RV's batteries to run when not plugged in. When plugged in it uses the AC and converts it to DC and runs the lights.
Please check your battery disconnect switch. It's most likely off. In my Winne there is a battery disconnect switch which disconnects the two batteries near the door. Lights wont work when unplugged and the switch is off. Lights works when plugged in or unplugged and switched on.
May 05, 2015 | Winnebago 2015 Ultralite 27RBDS
When i plug the cable into the joystick control (MK5SOJ+) all the lights around the horn button blink on and off motor wont engage and it won't shut off til pull out the cable do i need a
When you say the power cable I hope you mean the cable that comes from the main control module under the chair. I want to make sure you are not talking about the AC power cable that plugs from the chair to a wall outlet. So if we are on the same page about the cable is the one going from the joystick to the main control module under the chair and all you do is plug it in and the green speed lights start to blink this would indicate the joystick is bad.
Jan 23, 2015 | Invacare Pronto M51 Power Wheelchair
Samsung r540 wont boot
lets try something...take the computer and unplug it ..then remove the battery...with the battery set aside plug the wall plug back in and plug that into the wall outlet....then hold down the power button for about 2-4 seconds and let me know if it turns on or if there is any changes
then try a different power cable and if that doesn't work then the problem is with your motherboard....you can attempt to reflow the board by taking it all apart...make sure you remove everything that can be heat damaged...cpu ect.....then take aluminum foil and make 3inch soft balls out of it to suspend the motherboard so that it doesn't touch the cookie sheet pan....then bake at 400 for 10 mins...and after that if it still doesn't work then you need to replace the motherboard
Feb 17, 2013 | Samsung R540 Laptop
Mah8700ww maytag washer no lights on board pluged in
If you are looking for a control board for that model let me know I have two working boards.
Jan 02, 2013 | Washing Machines
Hi my Samsung R730 wont power up after shutting down when battery was low have tried pluging it in to mains and pressing power button but nothing works
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 13, 2012 | Computers & Internet
Pluged aspire 4520 in at night. next morning, no lights no power. nothing
if the unit will power one with ac adapter plugged in then you have a bad battery. check to see if you dc jack on the lap top lights up when you plug in the AC. if it does not light up then your dc jack or ac adapter is bad.
Jan 27, 2010 | Acer Aspire 4520-5582 Notebook
Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Logo
51 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
