Question about Brother HL-2230 High Yield Black Toner Cartridge Compatible
How do I remove a stuck toner cartridge
I have tried to remove it but it is stuck. Can it be taken apart and removed?
  • Rae Higgins
    Rae Higgins Dec 11, 2014
    Yes, I have. Thanks!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
Did you try to press DOWN the BLUE TAB that des-ENGAGE THE TONER FROM THE DRUM?
Posted on Dec 11, 2014
Testimonial: "Yes, I did! Thanks!"
  • Rae Higgins
    Yes, I did. Thanks!
Printers Led Screen apear i.e. "Toner not instaled"
remove and reinstall the cartridge.
Check the switch on the top( Whether smooth operation or stuck) if it stuck then apply little
lubricant .
Jul 23, 2011 | Samsung ML 1610 Laser Printer
My Brother HL 4040cn printer is leaking toner, black and yellow. It leaves spatter spots of these colors on printed pages. The machine does not have any messages. Do you know what this may be from or how...
If you've taken the printer apart and cleaned the belt unit and everywhere else in the paper's path, then it is probably either a bad toner cartridge or the drum. Since it's multiple colors producing splatter, its most likely the drum unit. Try taking the drum out and removing all of the toner cartridges and then clean the drums and corona wires. If its still producing splatter afterward, you've got yourself a bad drum.
Jul 20, 2011 | Office Equipment & Supplies
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
There are black smudges from toner on the "green roller" of the cartridge. Please advise how to remove these - taking the unit out and cleaning all around, blowing out toner etc, has not worked. The unit...
You didn't include a model number, and "no" cleaning it and/or blowing it off won't help you -in fact may make things worse. The "Green roller" you talk about is the drum, it needs to be replaced - unless it's part of the toner cartridge, then that's all you need to replace.
Aug 28, 2009 | NEC Office Equipment & Supplies
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
Unable to remove drum for cleaning
Remove the toner cartridge from the drum casing using the release lever. The drum is not to be removed from the drum casing. Just rotate the drum using the side button until you see the dirt mentioned. Use cotton swab to wipe dirt off. Be careful not to damage it. If that doesn't work, you need a need drum which is closely the same price as getting a toner cartridge. Refer to your Brother MFC 8840D manual that came with the machine. Alternatively, you can refer to the online manual.
Jan 07, 2009 | Brother MFC 8840D All-In-One Laser Printer
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Won't print - says 'paper jam 2' but no paper is stuck in machine
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Feb 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
PAPER BLOCKING
HI there I take it that you have a paper jam open the back door and check that there isn't any paper wrapped around the fuser roller you will be able to see it. If there is then push the little green levers down and try to remove paper from the cartridge side open front cover and remove cartridge if you can see the tail end of the paper pull slowly towards you. once removed close rear door and instll toner and start printing again. If you cannot remove paper from fuser then machine will have to be taken apart the remove paper. Also have you noticed any gray plastic film that has come out with the prints if so then the fuser film is broken and that will need a new fuser unit installed.
If the printer simply doesn't pickup the paper then remove the toner cartridge and using a soft cloth wipe clean the little gray rubber tyre that sits in the middle of the machine then test.
Hope this helps you as I didn't have a lot to go on but
Thanks J
Jan 11, 2008 | HP LaserJet 1300n Printer
Brother HL-2230 High Yield Black Toner Cartridge Compatible Logo
87 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
