Question about Samsung Refrigerators
How do you manually defrost a Samsung RF261 refrigerator and how long should the defrost cycle last.
I have a Samsung RF261BEAEBC/AA french door refrigerator with bottom freezer. A few months ago the fan started making noise and I found out from the web that this was a common problem because of ice build-up. So I followed some instructions that I found on the web to manually defrost the refrigerator. Press Power Freeze and Fridge buttons simultaneously and then select the defrost option. When I did this the first time, I was pressing all sorts of buttons, but I finally got the refrigerator to defrost and the problem was resolved for some time. Now, the problem is back. So I tried the manual defrost option, but what I notice is that the defrost cycle only runs for around 20 minutes. After I press the Power Freeze and Fridge buttons simultaneously for around 8 seconds, the display panel goes off. Then when I press any button, the panel toggles between "FF", "OF", "rd", "fd". I am assuming that the "rd" option is the refrigerator defrost and this is what I am choosing. The refrigerator keeps beeping for around 20 minutes, and then starts operating normally. But this just seems like a very short defrost cycle. Am I choosing the correct option to manually defrost the refrigerator? How long should the manual defrost cycle last?
    Habit-Forming:
  • 102 Answers
Defrost cycles in normal conditions can last from five (5) to 25 (25) minutes, depending on variables like humidity, runs times and how often the door is opened. Defrosting the unit manually as you've done is merely a short term solution as it recurs again over time. You should find out why it is not working automatically, as intended. This could be a problem with poor air flow (fan, blower or restricted air), a bad control, or even loose connections. Forcing defrost without correcting the underlying issue will not eliminate the problem.
Posted on Dec 06, 2014
How to access service Menu on Samsung Refrigerator 26Cf French model RF261 BEAE
look on the internet for a service manual from samsung and goo from there maybe it wants a new memory card fitted
Oct 31, 2014 | Samsung RF261BEAEBC 25.6 Cu. Ft French...
Why is there water in the chiller drawer on a French Door Refrigerator-Samsung?
We call that condensation from the moist vegetables, etc. in the chiller, natural occurrence.
Aug 21, 2014 | Samsung RF265AA Bottom Freezer French Door...
Condenser fan noise
you should have warranty from the tech at least one month ,but it sounds like motor fan is giving up umplug your fridge take off back bottm part to expose the fan and condenser clean all the lint in the condenser vaccum is better ,turn fan with your finger it should be very loose ant turn freely if it stucks its the motor ,umplug the motor pull the fan with the plastic base out of its place,take off the screw on the fan,pull and twist it by hand,take off two or three screws that is holding the motor to de base, buy a newone ,a the apliances store or online for about 45.00 put back everything in reverse way.plug your fridge, enjoy!!! good luck
Apr 07, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Noisy Fridge
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Apr 23, 2017 | Samsung RS2630SH Side by Side Refrigerator
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Fan is making a loud noise. When I open the door, the fan stops.
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Apr 23, 2011 | Samsung RF265AA Bottom Freezer French Door...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Refrigerators Logo
498 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
