Error Code F14 FDL F12
Tried to run the drain and spin cycle repeatedly. Took the top off of the machine, checked for separated wiring, broken wiring
  • 50 Answers
Look at machine for model number and serial number. We cannot help you without that info either. Google for a repair/owners manual that will tell you what the codes mean.
Posted on Dec 06, 2014
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Kenmore Front Load Washer
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
LG Tromm WM2075CW will not spin. I've done
Check first if repositioning the drain hose would help solve the problem. If your unit employs a drain valve, have it checked out. It has a solenoid or a small motor that opens and closes the part. Check as well the drain pump if it is running or no power is being supplied. Have the wire checked to see if there are loose connections.
Aug 27, 2009 | LG Washing Machines
Getting fault code f14?
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 15, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
