Question about Kohler Home
<!-- from fixya rte -->Cistern leaking into toilet bowl - Kohler Home
  • 4,159 Answers
There is a rubber valve that wears out.
see video
https://www.youtube.com/watch?v=cq6cnJOsqAA
Posted on Dec 06, 2014
gasman44
  • 83 Answers
SOURCE: When cistern fills with water it leaks into the
This is caused by the 'syphon' mechanism sticking, quite often nowadays the 'brilliant' plastic push button/ syphon combo sticks, and most toilets are fitted with an internal overflow, lift the lid on the cistern and check for anything causing an obstruction.
More often than not, it's a tiny bit of scale that causes such a headache, and the fact that nothing is made with any quality nowadays!
If you can't see what's wrong call a plumber, he/she will solve it.
I hope this helps
Steve
Posted on Jul 10, 2009
peterrance19
  • 399 Answers
SOURCE: after cistern refill outflow into toilet bowl
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Posted on Nov 15, 2009
  • 2841 Answers
SOURCE: hi, i have a caroma duel flush toilet possibly 10
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Posted on Jan 09, 2010
co7196
  • 3433 Answers
SOURCE: cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
Posted on May 26, 2010
  • 396 Answers
SOURCE: Water leakes continually into the toilet bowl from
the flapper is not sealing or the water level is set to high and you will need to lower the float. you will not need any parts to adjust the water level and the flapper is under $10.00. Click on the bellow link to see the parts diagram. http://www.google.com/imgres?imgurl=http://www.hometips.com/articleimages/20070913131246_plb_toilet_componentsdiagram1.gif&imgrefurl=http://www.hometips.com/how-it-works/toilet-plumbing-diagram.html&h=428&w=353&sz=34&tbnid=-jD50OHr-goZAM:&tbnh=247&tbnw=204&prev=/images%3Fq%3Dhow%2Ba%2Btoilet%2Bworks%2Bdiagram&hl=en&usg=__WY8gJuebzTLRKmtC489ClS9UH3s=&sa=X&ei=AikpTJXJHIK0lQf66vSCCA&ved=0CBsQ9QEwAA
Posted on Jun 28, 2010
How do i fix a leak from the cistern to the toilet bowl
There are bolts attaching the tank to the bowl check to see if they are correvtly tightened after you check to see if the gasket is properly seated.
Dec 25, 2014 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
Jun 09, 2014 | Toto Aquia II Dual Flush Toilet
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Is it possible to replace just the cistern instead of the entire toilet set? I have had water leaking problem in my toilet. The water is running from cistern to the bowl whenever the cistern is fille
It is likely that the leakage is being caused by a worn-out flapper or seal (the part the flapper seats on). You can buy after-market kits that have replacement parts. What is the make and model of your toilet?
Nov 30, 2017 | VitrA Aria Toilet with Elongated Bowl/...
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
Sep 04, 2011 | Caroma toilet - water saving Sydney Low...
Cylpso Toilet Suite D-18156 Slow leak into bowl
You need to replace flapper which is available at where plumbing products are sold,even walmart has them.
Jun 10, 2011 | Kohler Plumbing
How do i fix a cistern that is continually leaking in to the toilet bowl? i have tried to open the cistern at the flush button unit but do not want to force open. tried twisting but is quite tight.
most modern toilets do not have an overflow pipe to outside instead they overflow into the bowl itself so have to adjust level so it does not overflow into return
Apr 02, 2010 | Toto Aquia II Dual Flush Toilet
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Home Logo
90 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
