55 inch vizio. Lost all sound just hear loud buzzing out of left front speaker!!! Do I fix or buy new tv???
    Sniper:
  • 73 Answers
Roughly $250 U.S. to fix if you're not handy replacing electronics yourself. If you are handy then you can search for the audio board on ebay, but you need to know the exact number of the board.
Posted on Dec 06, 2014
SOURCE: Buzzing sound on Vizio Plasma TV
hums when certain appliaces are used washer microwave skill saws
Posted on Feb 02, 2009
  • 63 Answers
SOURCE: LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Posted on Aug 19, 2009
SOURCE: 37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Posted on Jan 05, 2010
  • 8457 Answers
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Posted on Apr 07, 2010
SOURCE: lg 47 inch tv sound
I have the lg 47 lcd and i had the same problem for about 1-2 months ,but out of the blues the sound just got really louder ,i think the speakers broke in and it the sound normalized.But my tv sounds great now , my kids even asked me if i did something. Maybe just give it a little time.
Posted on Dec 13, 2011
Low volume
If it's a new TV, then it might just be as high as it goes. A lot of HDTVs don't come with great speakers due to the small flat feature of the TV not allowing anything better.
You will have to get external speakers for the TV to experience better sound.
Here is a great sound bar that is well priced. http://www.amazon.com/Vizio-VSB205-32-Inch-Theater-Soundbar/dp/B004VGI2EK/ref=sr_1_2?ie=UTF8&qid=1359416740&sr=8-2&keywords=32+inch+sound+bar
I've personally heard that sound bar and they are surprisingly loud and hardly take up any room at all.
Jan 28, 2013 | Polaroid TLA-01511C 15 in. LCD Television
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Aug 19, 2009 | Vizio L37 Television
Loewe Articos 55 HDTV loud buzzing noise
sorry cant solve it ,i called all the loewe service agents and they all said the same thing, put up with it. a new engine/colour wheel cost around $2500,
Aug 27, 2008 | Loewe Articos 55 55" Rear Projection...
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
