Question about Apple iPhone 5S
Sound doubletap commands how do i disable
Tried to put in code will not respond, tried to use fingerprint but will not let me as it has just been turned on and is not yet working with fingerprint
    Problem Solver:
  • Apple Expert
  • 73 Answers
This is the only way I know of...
http://support.apple.com/en-us/HT1212
Posted on Dec 09, 2014
MB C230, All windows do not work.
Keep researching that alarm pad. Sounds like the system has been locked out by a security setting. The alarm system has to be told all is well, disable, return to barracks.
Nov 26, 2013 | Mercedes-Benz Cars & Trucks
Hp envy of unlock passeord
Which operating system ???
CMOS (Complementary metal oxide semiconductor) refers to the battery-powered, semi-conductor chip located on an HP computer's motherboard.
It is where the BIOS stores important information regarding the PC's system configuration. CMOS is required for an HP laptop and its hardware to run stably.
Sometimes, however, it is necessary to clear CMOS, such as if you lose your BIOS password or your BIOS is corrupted.
Clearing CMOS on HP laptops varies depending upon the model, but for a lot of laptops, the process simply requires removing the battery for a short period of time.
Power down your HP laptop. Remove the AC adapter and any other peripheral devices. Turn over the computer so that the bottom side is facing up.
Ground yourself, either by touching a piece of unpainted metal or by wearing an anti-static wrist-strap.
Locate the battery. This will vary depending on your laptop's model, but it is usually located on the back, near the rear of the laptop.
Review your laptop's documentation to find the battery, if needed.
Many newer models require that you remove the battery by releasing or holding down one or two latches, then gently pulling the battery out.
Some models may instead require that you unscrew the battery from its compartment.
Leave the battery out of the compartment for at least 30 minutes.
Do not attempt to turn on the computer and do not touch the battery within that time.
Some HP laptops may require you leave out the battery longer to clear CMOS, others might take only 10 to 15 minutes to reset.
Ground yourself, then put the battery back into the HP laptop.
Snap the battery latch into place or screw the cover back on, if necessary.
Removing a Bios - CMOS Password
http://www.dewassoc.com/support/bios/bios_password.htm
Disable Fingerprint on an HP Laptop
Many HP laptops include a fingerprint scanner to enhance the security of your computer.
When the fingerprint scanner is enabled, the computer requires a fingerprint scan to log onto Windows.
Disable the fingerprint scanner if you do not need or want this feature.
With the fingerprint scanner disabled, you can log on to Windows using a password.
You can enable the fingerprint scanner anytime you need to.
Access the Device Manager on your computer.
Select "Control Panel" from your computer's Start menu.
Click "Hardware and Sound" and then click "Device Manager."
Find "Personal identification devices" in the "Device Manager" list.
Click the "+" sign next to "Personal identification devices."
This opens a list of all of your devices.
Click on "Validity Sensor."
Select the "Driver" tab at the top of the properties window and click "Disable" to disable your fingerprint scanner.
The button changes to "Enable" and you can enable the fingerprint scanner at any time.
Click "OK" to exit out of the window.
Jun 27, 2013 | Computers & Internet
Command and Conquer 3 Tiberium Wars: When installing the game using my built in DVD drive, i get an error saying that 'SPMaps.big is missing, please check to make sure the file is there and that you can...
The most common reason for this is your CD. Make sure your CD is free from fingerprints, smudges and scratches.
Let me know if that doesn't work and we'll try to figure out what the issue is.
Mar 28, 2011 | EA - Electronic Arts Command & Conquer 3:...
Finger print enrollment
The security software should have been installed at Toshiba. If not it is easy to download and install. You should have a biometric coprocessor driver which runs the scanner. That sounds like what is missing. If you had to reinstall windows this may not have been put back in.
To get the drivers go to www.toshiba.com and then click on support.-mobile computing - drivers download. This pops up a new window that you now have to click on what model you have. I have a Tecra A8 201E so I click on notebook in the left, Tecra, then A8 and then on 201E then click on the go button. You should filter by operating system so you are only looking at the right drivers. There are three downloads for the security. One will be called HDD security, TPS Trusted Platform Security, and Fingerprint software. If you download those and save to your desktop then you can easily run then as needed. When you have them run the one called fingerprint software. That should install the scanner drivers and may be all that you need. Try running it after installing this. Make sure your backup password is something you can remember. If your scanner fails and you can't remember that then you can get locked out of your computer.
The TPS provides some other tools such as a 'safe' that saves files in an encrypted area. You can disable it if it inteferes too much.
The HDD utility locks the hard drive which can stop people from using your computer as they won't have your fingerprint to unlock the drive.
Apr 27, 2010 | Toshiba Fingerprint Reader
Its slow to command,when your typing your commands onthe phone, it slow to respond to the command.it does not keep battery charge for long
go to performance and maintenece center . - > choose options to enhance Battery Life - > (disable Areo Effects , Etc) This should enhance Battery Life
Mar 21, 2010 | Microsoft Windows Vista Ultimate Edition
I am a tyre finnisher 4 michelin and work with hot rubber which burns my hands and also the materials i work with have lots of thin wires in which my fingers get jabbed and grazed so my fingerprint scanner...
just click right on the my computer ...than properties..than hardware ...and device manager ...
here you will find all devices...pick up this one ...right click and uninstall .or disable...I prefer disable ...or both ..
this is not a permanent solution ...whenever you need it back ...just refresh by scan for hardware changes and reinstall it's driver ...this will be back on like new...
Jan 18, 2010 | Computers & Internet
How to use password instead of fingerprint to logon
How to disable fingerprint reader
In Windows, in the settings section of the Fingerprint Control Center, uncheck Replace windows logon with fingerprint protected logon. In the Fingerprint section uncheck the Power-On Security section if the user has fingerprints enrolled there. You do not need to uninstall the software unless you wish to.
Nov 12, 2009 | Microsoft Computers & Internet
Error code 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted.
Number of possible causes, check the phone line, try a different fax number for a start. Is there other fax machines in the office on the same line
Sep 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I disabled my fingerprint sensor, how can i activate it again? appreciate your support
Dear sir,
If you are diabled fingerprint sensor in BIOS,go to the bios enable finger print sensor.
If you are disabled fingerprint sensor in windows.
Enable it in device manager of control panel.
Aug 08, 2009 | Acer Aspire 5720-6661 Notebook PC
The cursor doesn't respond to commands given using mousepad.
Sounds like a malfunctioning touchpad. You could try an external mouse and disabling the touchpad in device manager.
Dec 13, 2008 | Dell Latitude D600 Notebook
Apple iPhone 5S Logo
49 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
