Question about Rainbow Vacuums
How do i make sand on little alchemy
Earth and plant dust and gunpowder rainbow and plant earth and dust
    Sergeant:
  • 272 Answers
Rainbows don't really trap as much in the water as the salesman says. That's why they don't want you to suck up drywall dust. To the extent that dust floats in the air, it also stays just as suspended in the bubbles as they go through the tank. When the bubbles pop at the surface of the water in the tank, much of the airborne dust isn't trapped and gets sucked through the motor. The idea of sucking gunpowder through a Rainbow sounds interesting. There's sparks flying around the commutator in that motor and you could possibly have dust going through. Id like to watch you suck up gunpowder.....from a distance.
Posted on Feb 06, 2015
Why is my rainbow d4c kicking out so much dust?
Do you have the water level set right? Is there an elbow missing inside the tank?
Jul 27, 2014 | Rainbow Generic D4c And D4ce Fan Assembly....
Rainbow power head dusty
Have you checked the channel from the brush roll area to the hose for blockage? Dust accumulation is usually a sure sign of an obstruction.
Nov 07, 2013 | Rainbow E series Canister Wet/Dry Vacuum
My e series rainbow has stopped picking up and the dust gathers on the top of the nozzle. It will pick up a little when I push it forward, but when I pull it back dirt and debris comes out of the noz
<p>Did you recently remove the brush roll? If you installed the brush roll in backwards, then this can happen. You can <a href="http://www.rainvac.com/rainbow-vacuum-manuals">download the manual </a>on how to replace your belt and install brush roll correctly.<a href="http://www.rainvac.com/rainbow-vacuum-schematics"></a></p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Feb 23, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series shooting out dust
Did you place water in the water pan? Are you picking up drywall dust, baby powder, wood ash, etc.? This type of material is difficult to be trapped by water.
RainVac
www.rainvac.com
800-523-0510
Mar 31, 2012 | Rainbow E series Canister Wet/Dry Vacuum
What would happen if I would take out both hepa filters from my rainbow e-series? I do need extra super filtering - previous versions didn't have it and it was ok... Hepa filters are not so expensive...
It won't hurt anything if you don't have a problem with the tiny particles that will be blown into the air. The Hepa filters trap small particles that can be unhealthy to breath. Most of these particles consist of human skin and hair, pet dander, dust mites, etc.. Many people are not bothered by these tiny particles. Others, like asthmatics, can have serious complications from them and the Hepa filters really help.
Nov 24, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum was used to clean up after plaster sanding.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=645474
Generic problem for all Vacuums
Posted by veronica1113 on Jun 04, 2008
Could the debris from plaster sanding cause my rainbow series D4C vacuum not to work? If so how is the best way to clean it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Rainbow D4C will still work but not @ the highest efficiency rating – the suction will be reduced because the sheetrock dust gets into the motor and the fan blade(s) Quan 3 and would need a professional cleaning 1st or 2nd. Replacement of the motor; if it is too serious and or too expensive. It’s a good vacuum back it is suggested that people use a good Shop Vac for the sheetrock dust removal. Feel free to contact your local vacuum cleaner dealer in your area or you can try to repair and change out the fans, clean out the carbon brush area and cleanup the armature. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
I can't take apart the Rainbow Rainmate to clean it.
The E series has a clear plastic window on each side that you remove to get to the screws, remove them and it will come apart. Some will have tabs instead of screws.
Mar 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum Model D3B
If it won't work without a ground wire, but still works with one, then you must have a ground/earth connection to make it work - it sounds like there is a safety device that needs an earth to release, you could almost certainly bypass this relatively easily, but it will be there for a good reason and that would be dangerous. Bearing this in mind, regardless of which 2/3 prong adaptors you use, without an earth connection it will not function without risk probably of electric shock from the case or damage to the vacuum, else the safety device would not be there. Get an electrician to your home, and make him install grounded sockets where necessary (should be all, but at least get a couple). Ungrounded/unearthed domestic power sockets at all domestic AC voltages are lethal eventually, to man or machines. A lot of devices don't need an earth, but especially something with a big motor or a metal case usually does. At least ask a local electrician what he thinks. If you want to do it yourself, an Earth circuit in your home is not too hard to achieve if you have basic wiring skills (and access to the ground floor), but most insurance would dislike the idea - if you want to - post again and I may talk you through it. Hope this helps :) Please be careful :(
Mar 24, 2007 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
122 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
