Question about Pure Country Weavers University Of Ga On My Mind Wall Hanging - 1Y80V8N
My neighbour has knocked down my party wall and built a fence with concrete posts and wood panels, he has enchroached on my land and now my brick shed is in his garden by 30 inchesx15 yds long. what c
The solicitors but hey are too expensive and I am a pensioner.
  • 9,771 Answers
Kick the fence over and show him where your property line is.
Posted on Dec 06, 2014
Testimonial: "I can't because I would be arrested for criminal damage!!"
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Are 6mm screws strong enough to hold mirror that weighs 7.92kg
It depends on how good your plugs are and what is the wall built with (wood,dry wall,concrete,brick)
Jul 17, 2014 | Home
How deep into the ground should i sink my concrete fence posts
At this stage, with the posts already bought, I would say concrete is the best way out. Dig holes twice the size of the posts, or more, two and a half feet deep and set the posts. Make sure the spacing is perfect, so the fencing fits properly. You may need spacers and supports to set the posts straight and true.
Set the posts high enough to support your fence. Sketch it out, the posts may not have to be as tall as the fence, they only have to reach the top horizontal board.
Nov 27, 2013 | YouTube Videos
Our neighbour has neglected his garden entirely, bramble has FILLED his garden! It is pushing our fence over. It has damaged/broken our fence once last year, we complained in writing, he ignored. We
Truly, if you have reported everything accurately, you have done an admiral job of trying to rationally and generously deal with a difficult problem. Take all of your documentation that you have, including the receipts for the letters you sent. Hopefully you have copies of the letters you sent the landlord, if not, then resend similar letters and keep copies, making sure you get the signed receipts, then TAKE ALL THIS TO A SMALL CLAIMS COURT and ask the clerk what form/s you should fill out to take this person to court. The court will hear your case and look at the evidence you present. It seems that you have a very good case to obtain a court order, enforced by police, for the landlord to co-operate with you. Before you do anything, make sure you have copies of the letters you sent to the landlord explaining your position and what you are willing to do to resolve the problems. When you have that in your possession, AND ONLY THEN, and he doesn't reply, send him another registered letter that requires his signature, informing him that you have no choice except to bring him into court. MAKE SURE YOU MAKE A COPY OF THAT LETTER TOO. THAT may be enough to get him to co-operate with you. If not, take him to court.....you should win, if justice and integrity prevail.
Sep 20, 2012 | Cars & Trucks
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
I bought a board game called knock out by Milton Bradley. There were no instructions on how to play. Do you know the rules on how to play?
The wiki for the game has the rules ill post them here for convenience:
Before the game begins, a wall of 24 bricks (plus one "Knockout" brick) is constructed. A template is provided to assist where the bricks should be placed in the wall. These bricks can be 1, 2, or, 3 blocks wide. The bricks are made of clear colored plastic. The 25th brick, also known as the "Knockout" brick (colored solid black in the Milton Bradley version and solid blue in the Hasbro version) is three blocks wide, and is placed on the top of the wall, directly in the middle. The template shows exactly where to place this brick as well.
Players first must roll a special die that has four colors on it and two stars. If a color is rolled, the player must knock out a brick of that color, out of the wall. If the player rolls a star, the player may knock out any brick they wish (with a few exceptions, see below). Players take turns using a motorized hammer known as the "Rammer Hammer", in an attempt to knock out the specified brick out of the wall, without making the wall collapse, OR making the "Knockout" brick fall off the wall. If a player is successful in knocking out the brick, without the wall collapsing, or the "Knockout" brick falling off the wall, they must put the brick back, on the top of the wall. Each player thereafter must accomplish the same task.
The rules for hammering are:
  • A player cannot touch the wall in any way, except with the hammer
  • Once you begin to hammer a brick out of the wall, a player cannot change their mind, even if it becomes obvious that hammering the brick any further will make the wall collapse.
  • A player cannot hammer any brick on the same row or a row higher than the "Knockout" brick
A player is allowed an attempt to make the wall more stable by using the hammer to stabilize the wall before they commit to hammering out a brick, but once a player starts to hammer a brick out of the wall, they can not change their mind.
If at any time during a player's turn, the wall collapses, or the "Knockout" brick falls off the wall, that player is eliminated from the game, the wall is rebuilt, and play starts again with the next player in line.
If only one player remains, they win the game.
Apr 15, 2011 | THQ Video Game Consoles & Games
Biesemeyer fence not parallel to blade.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
Feb 28, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Routers
Our office network uses the router it goes through three walls to the other side of the warehouse for about 70 feet.
Apr 25, 2008 | Linksys Wireless-G WRT54G Router
Pure Country Weavers University Of Ga On My Mind Wall Hanging - 1Y80V8N Logo
745 people viewed this question
Top Pure Country Weavers Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
samiya_jahan
Level 1 Expert
Are you a Pure Country Weavers Event Planning and Celebration Expert? Answer questions, earn points and help others
