Question about Sony Televison & Video
I HAVE A SONY KP53V75 PROJECTION TV CAN I FIX THE CONVERGENCE WITHOUT THE REMOTE
I HAVE A 3IN 1 REMOTE 15-2143 BUT IT DOESNT MOVE THE ARROW TO THE RIGHT
  • Sony Master
  • 9,587 Answers
If there is a menu button the TV then you probably can. Try shopjimmy'd web page to see if they have a factory remote.
Posted on Dec 06, 2014
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
Misaligned convergence on sony kp-65ws510
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 08, 2010 | Sony KP-65WS510 65" Rear Projection...
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
Sony rear projection tv is blurry and looks like 3D. Picture also will go black for a second or two now and then. Any ideas?
  • Screen looks 3D
May 13, 2010 | Sony KP-61HS10 61" Rear Projection...
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My sony kp-51ws510 tv picture looks slanted and 3D blurry. How can I fix it on my own?
  • Screen looks 3D
Sep 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony kp53v75 TV with blue convergence off right by half inch
it is a convergence problem u may have 2 replace conv ic's and some resistors
May 11, 2009 | Sony KP-51WS500 51" Rear Projection...
Wide screen t.v. picture problem
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 05, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a sony wide screen projection t.v.(2003)...when i turn it on it looks like i'm watching a 3d movie without the glasses...the picture is also curved...any ideas?
Screen looks 3D
>>>Solution<<<<
Converence
green is fixed so you have to move red and blue to green.
by using the remote you may find a simple converge function and open this and using arrow keys move the blue or red first to center of screen, repeat for other color you should see the lines moving toward a a white center point.
if the lines do not move with remote try manual ...menu on the set. if still no movement you have a problem on the convergence board and need a tech to fix.
A service manual will explain complex convergence to the detail .
but this might take hours to get it right.
Aug 09, 2008 | Zenith R56W36 56" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
