Question about Samsung HP-R4272 42 in. Plasma HDTV
After 30 Minutes and the picture distorts
I have a "new" (I believe it was a store demo model for about 2 months) Samsung HPR4272. After approximately 30 minutes of a movie (I have tried Hi Def, regular dvd's, and OTA TV through HDMI, S-video, RCA, and Component connections) the picture starts to pixilate and get grainy at the top of the screen and gradually increases throughout the picture.
At first I thought it was a bad spot on the DVD as it seemed like the resolution was just bad (blurry edges and so on). Then I noticed it throughout the top of the screen gradually working its way down. It is most noticeable on white as it seems like the rgb don't line up and the resolution appears to be terrible.
I have tried placing a box fan directly behind the TV and that did not seem to help (I thought it seemed like an overheating problem).
Any thoughts are greatly appreciated.
Re: After 30 Minutes and the picture distorts
Would that be on the DIGITAL VIDEO BOARD?
If I were to replace one of the boards to fix the problem, which board?
Posted on Aug 25, 2009
  • 179 Answers
You can adjust the v_set and the v_scan voltages anout 15 vdc lower.(they are on a little board to thr right of the power supply board) this has a good chance of correcting the problem.if not then the panel itself is bad..this set had a 2 year warranty, and even if it was a demo with your bill of sale you should have no problems with having it repaired. if you have no bill of sale and cant get carefule as there is dangerous voltage in a tv set
Posted on Dec 01, 2007
0 characters
3 Points
My tv model number is 60lb5900-uv how do I get it off of store demo
How To Take Your Tv Out Of "Demo Mode"
Samsung ElectronicsMay 21, 2012 - There are 2 ways to take your tv out of demo mode. ... When the message, "Menu language, store demo, and time will be set", and then press ...
Samsung: LN46B650 is stuck in Store Demo mode - Forums - CNET > Forums > Samsung
CNETI just bought a Samsung LN46B650 and it is stuck in Store Demo mode. ... If you do get prompted to choose between HOME or STORE mode (and you might), ... on the tvfor 10-15 sec(i did almost 30)...but the store demo mode wont turn off.
Samsung HDTV - Disable Store Demo Mode (UN46D6003 ...
? 0:39
Nov 28, 2011 - Uploaded by SPSN
Jan 19, 2016 | Flat Panel Televisions
The demo mode apears every 30 minutes. I can't really stand it. How can I shut it doen for ever? Sharp aquos LED 40"
I'm not certain of the specific model number of your set, but this should be the same for all Sharp Aquos models.
First, navigate to TV input, and select menu
Next, enter setup and select, "ez setup"
In the ez setup menu, select "home", not "store", for television location.
This should turn off the demo mode and solve your issue.
Jun 10, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
Problems with the picture mode on my samsung 46''
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Flat Panel Televisions
Westinghouse LTV-37w2 HD picture malfunction
Have the same problem, have found others too, but no solution yet...
Jul 15, 2008 | Flat Panel Televisions
Samsung HP-R4272 42 in. Plasma HDTV Logo
246 people viewed this question
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
