My printer has been working ok never have used it much but now when i try to turn it on i mash the on button and it starts to scan and then just dies.
Unplug and reconnected it will start to come on and then stop
    New Friend:
  • 26 Answers
Open and check if there is a paper jammed inside
Posted on Dec 06, 2014
Canon mp130 printer; readout says; waste ink absorber is almost full
This runs of a counter and not off the actual amount if ink in the absorber, so re-setting it once or twice should be fine. Try this method below.I found this solution from another user on FixYa.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
I hope this helps, If so please rate this response Thank you for supporting the Fix-Ya Community
Regards GM
Apr 17, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Trying to scan photos to computer, does not register that i am pressing the ok button to start scanning; on the screen it continually says: place document on platen glass and press (button). have tried...
The first thing I would assume is that your are connected to this through a wireless network. I have another model of the Pixma printer and I have the same issue whenever I try to use the buttons on the printer to scan. For some reason that button does not realize where you are trying to scan to over the network and will not work. In order to scan you have to start it from the GUI, not from the printer itself. Hope this helps, if you have any more issues let me know.
Apr 11, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I want to Scan a page on Lexmark X6150. Please guide me how to set the Options and Select buttons. I pressed the start button after pressing the scan button. It does do anything.
Find the "menu" button on your printers keypad and push it. Use the up and down areas on the printers keypad to advance from choice to choice. Find the option that says something similar to "scan settings" . Push the "ok" button or the "enter" button on your printers keypad to open this option. Continue scrolling with the up and down arrows and using the ok or enter keys on your printer and locate the "scan to" choices. Set up your software choice for scanning text documents and pictures. Most people want to open and edit text documents in software like "Microsoft Office" in your computer. Choose a photo editing software installed in your computer to send pictures scanned on your printer to. When these settings are set and saved, turn on both the computer and printer and try scanning from printer to computer again to check and see if the problem is solved. If you experience any other issues, pleas clarify what they are and I will try and help you solve this right now before I leave for work.
Sep 27, 2010 | Lexmark X6150 All-In-One InkJet Printer
Waste Ink Absorber is almost full
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
PRINTER PixmaMP 130
HI
You can try.
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
All best
Dec 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
When I try to scan, I get error message on printer that says No Scan Options. Press OK to continue. I have to put the cd back in the tray and run it again in order to use my scanner.I've turned it off...
I think you have installed the HP full feature software in the computer.
You can check it, you need to click on Start button -> All Programs -> HP -> HP Director
please check if you are able to scan from HP Director (if yes then change the below settings so that you would be able to scan from the button on the unit)
open the HP Director -> click on "settings" -> scan settings -> scan to setup and you need to populate all the options which you see in the left panel. when you will populate all the options to right panel. Then click UPdate device or OK button. and then try to scan again from the button on the unit. It will work. If it does not then check for the DIM (Digital imaging monitor) icon in the system tray, it would have a green checkmark over it. if you do not see it then you have to start it from the below steps
please click on Start button -> My Computer -> C: Drive -> Program files -> HP -> Digital Imaging -> Bin -> hpqtra08.exe when you will double click on the file, you will see DIM icon in the system tray and you will be able to scan from the button on the unit.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01798218&cc=us&lc=en&dlc=en
you can also click on the above link to understand it better.
I hope it will definitely help you out.
Dec 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
MY SCANNER DOESN'T HAVE A SCAN BUTTON && I DONT KNOW HOW TO SCAN!
try scanning through your printer/scanner program on your computer. This worked for me
Jun 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Can not scan to computer
hi,
below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab.
    NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
Thank you so much.
adonscott
Jun 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
HP All-in-one will not scan
I think I have the solution for you (after facing similar problem). Try installing the drivers and then go to my computer right click on the HP and select "Scan using wizard". My HP is able to scan using this method although I still can't scan using the button on the printer so if you don't mind clicking the mouse instead of the printer's button you should be fine. Let me know if it worked. Cheers, D.
Jun 08, 2007 | HP OfficeJet 6210 All-In-One InkJet...
29 people viewed this question
k24674
