Question about Mitsubishi Televison & Video
Where is the ballast located on the 62725 - Mitsubishi Televison & Video
    Master:
  • 706 Answers
What is a 62725, you need to put more information in your question
Posted on Dec 06, 2014
I have a Mitsubishi dlp WD62625 tv and I had a new bulb installed in Nov. 2010 by a tv repairman. After installation he re-set the tv but the yellow/red light wouldn't go off. So everytime I turn the tv on...
the bulb wire go to the ballast board, they do wear out over time but is usually down to capacitors, also depending on how much you watch the tv its about time to change the bulb as they only last a certain amount of time any way. when the tv is reset properly it will count down on time used. from new bulb. its only an estimate, if you are having difficulties seeing the screen the bulb is on its way out.
Jun 12, 2017 | Mitsubishi WD-62725 62" Rear Projection...
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
My television is cutting off and takes forever to restart. the green light stays on. I have tried to reset the tv. same ol thing. replaced the lamp its not that. a big blue screen pops up before shutting...
Hello! If you haven't replaced the lamp before, I recommend you do it, since it's already 4 years old. If you already replaced it, there is a possibility you might be having a ballast issue. The ballast is the board in charge of sending all the power to the lamp so it can light up. www.discount-merchant.com/?Click=48427 These part are not that expensive and will get your TV up and running.
Nov 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking Green light after Capacitor kit replacement WD-62725
I just repaired two Mit WD-62725 sets in the last two weeks.
The first one had bad caps on the power board and the FMT board. The scond one had bad caps on four out of the five boards.
Also, on the FMT board, there was a blown surface-mount fuse.
I advise checking all of the boards for bad caps. If you fine a bad 1000uf cap, replace all of the 1000uf's on the board.
Hop this helps,
Dan
Sep 03, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Lamp Issue with Mitsubishi WD-62725
Hi I am Vortash it sounds as if the actual fault is in your ballast circuit this is the circuit that fires up the arc on the lamp and sends the signal to the main board that the lamp is running , if this is faulty no signal is received by the board and the lamp light comes on when this happens there is usually still sound but not always as sometimes the problem affects the power supply also .. this is a job for a trained engineer as voltages at the ballast are sometimes in excess of 25000 volts at first arc that then settles to a lower voltage to run ... regards Vortash
May 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD 52525 lamp ballast avalability
Contact Mitsubishi directly, and find out who their authorized parts distributor is. Mits may sell one directly to you.
It is an expensive part to begin with.
Jerry G.
May 02, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Ballast is loose and not connecting to the new lamp . . . Any suggestions?
whats a bulb? whats a ballast?
try calling an expert for I don't even know what you mean.
Apr 28, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Red light
There are two 3300Uf @ 35V capacitors that will cause that problem they are located on the PWB. they are right next to each other and the only ones with that rating on the PWB board
Apr 10, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
