Question about Moultrie Cameras
Transfer pictures from my moultrie game camera to my iPad I can't make it work
Min USB and wyfi sd card's a little bit of everything
  • martinpk Dec 06, 2014
    Hi tanner nichols, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Have you successfully transferred images from the SD card to your computer?
SOURCE: sd locking
I had this problem also. To solve the problem I blew into the slot where the card goes and it then read the card. If dirt gets into the port it causes the sd card to lock. You may have to use a pressurized can of eletronic spray to clean the port.
It worked for me.
Posted on Mar 04, 2009
SOURCE: moultrie game camera won't flash
we get beutiful day pics, but totally black pics at night
Posted on Aug 23, 2009
  • 3289 Answers
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Posted on Oct 20, 2009
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
Posted on Dec 26, 2009
  • 296 Answers
SOURCE: Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Posted on Mar 06, 2010
My Moultrie M880 game camera is set to take 3 pictures, so once I place the SD card in turn on and I have in a area with no moving grass or limbs the camera will take pictures non stop. I will check i
Post subject: Re: M880 problem Solved .... icon_post_target.gifPosted: Tue May 27, 2014 3:48 pm icon_user_offline.gif
First of all, ONLY USE THE STANDARD SPEED SD CARD THAT MOULTRIE ADVISES.
Second, DO NOT TAKE THE CARD OUT & USE A READER WHILE LEAVING THE CAMERA MOUNTED (this will lock up the camera).
Third when using a brand new standard speed sd card, DO NOT FORMAT THE SD CARD IN ANYTHING OTHER THAN THE CAMERA.
One could clear the camera by reseating the battery (take the battery out & put it back in). The reset button (up inside) is not always necessary for this.
You probably got a different speed card to somehow work & the camera malfunctioned. Bear in mind the aforementioned advice.
Nov 29, 2014 | Moultrie Cameras
Bluetooth video feed to iPad
Normally you can't connect a camera to an iPad. If you want to put pictures from your own camera on the iPad, you can use a Camera Connection Kit. for the iPad 1 to 3 (30 pol connector) there are two items. One you can put in a SD (SCHC) card and import jpg pictures to the iPad. If your camera has no SD cards, you can use the USB connector. With a USB cable you then can connect the camera and you can retrieve the jpg pictures from the camera to the iPad. for the iPad 4 gen and 5 gen you have to buy the lightning connector with SD card reader. The camera connection kits only work on iPad not on iPhone. The card I now will mention, also work with iPhone.
Last option is to buy a Eye Fi card or a Trancend WiFi card, as long as your camera is compatible with such a card. (read the manual) and get a free app from the app store for the card you bought. Theen you can view or download the pictures while you are shooting. Last option is slow and while connected to the WiFi card you can't access the internet is you have a wifi only iPad.
Nov 28, 2013 | GE Add-On Wireless Digital Color Camera...
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
Resetting the Moultrie A-5 Game Camera
HARD RESET TAKE OUT BATTERIES SD CARD PUSH THE ON OFF BUTTON FOR ABOUT 5 SECONDS LEFT EVERYTHING OUT FOR 2-5 MINUTES. THEN PUT THE BATTERY BACK IN TURN THE CAMERA ON IT SHOULD SAY NO CARD. THEN TURN IT OFF THEN PUT THE SD CARD BACK AND TRY IT IN THE DARK AREA TO SEE IF THE FLASH WILL GO OFF. IF THAT DOESN'T WORK WILL NEED TO SEND IT IN FOR REPAIRS.
Nov 07, 2013 | Moultrie A-5 Game Camera
My pictures at night are nothing but a black picture
HARD RESET TAKE OUT BATTERIES AND SD CARD, TURN IT TO THE ON POSITION FOR ABOUT 2-3 MINUTES WITH NOTHING IN IT. AFTER 2-3 MIN PUT BATTERIES BACK IN WHILE WITH THE ON POSITION IT SHOULD SAY NO CARD. ONCE IT SAYS THAT TURN OFF THE CAMERA PUT THE SD CARD BACK IN TURN THE CAMERA BACK ON AND TEST IN THE DARK. IF THAT DOESN'T WORK SEND IT IN FOR REPAIRS TO MOULTRIE.
Nov 07, 2013 | Moultrie Game Spy D-333 Game Camera
THE IMAGES CAPTURED AT NIGHT ARE SO DARK THAT WE ARE UNABLE TO VIEW THEM. WE CAN SEE SHADOWS IF DEER BUT CANNOT FIGURE OUT HOW TO GET AN ADEQUATE PICTURE AT NIGHT.
Turn camera off take out battery's and sd card. Once everything is out put it to the on postion for about 2-3 min. Then put battery's back in with the camera being on still leave sd card out. Once it says no card turn camera off then put sd card back test in dark. If still not working call Moultire 8006533334 option 1 and 1 for a live person.
Sep 30, 2013 | Moultrie Game Spy C-90I 10.0Mp Scouting...
Moultrie game camera flash will not work. All bulbs light up red but every night picture is so dark
Try doing a hard reset, Turn camera off remove battery's and sd card. With everything out. Push on/off for about 5 sec. Put good battery's in ig. If you using cheap battery's make sure your are using Duracell or Engerzier battery's not rechargeable. Also make sure not using a micro sd card and nothing higher than a class 4 which is the speed of the card not the size. If still need help call with equipment to troubleshoot to Moultire 800653334 option 1 and 1 for a live person.
Aug 31, 2013 | Moultrie A5 Game Spy Low-Glow Infrared...
I have Moultrie game camera 160 ,the problem is that most of the pictures are only black and white .....only a few are in color ! What am I doing wrong ? Also when trying to veiw my pictures on the TV...
The camera defaults to black and white in low light conditions, so only daylight pics will be in color. Any SD card should work fine, but you may need reader software -- check your operating manual.
Bill B
Aug 19, 2010 | Moultrie Cameras
Moultrie 40 spy camera will not put photos on sd 1gb card
TRY A DIFFERENT USB PORT ON PC...usb has 2 standards...1.5 and 2.0...new Dell,at least, has 1.5s on front;faster 2.0 usb ports on back...2.0's will drive 1.5 devices, but 1.5 ports won't drive 2.0 devices
Aug 31, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie D 4.0 continous exposures
..your not in "Interval Mode", are you?? IF your cam is set to start an "interval @ say 2400hrs( midnight) and to take pics every 1 min./5 min/;ect., IT WILL!
Make sure you're in "AUTO MODE"...It's easy to accidently hit the mode switch when moving the power switch from off to on..(I didn't find this out by reading a book...)
Feb 22, 2009 | Moultrie MFH-DGS-100 Digital Camera
Cameras Logo
66 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
