Question about Canon PIXMA Office Equipment & Supplies
My canon pixma MG3155 has a piece of paper jammed> I have managed to get some of it out but the rest won't move. Can anyone help
When I turn on the printer it tries to eject the paper and is making a screeching sound.
    Master:
  • 560 Answers
Turn the printer around and remove the rear paper holder. This will give you access to the paper.
Posted on Dec 06, 2014
jackboy
  • 2985 Answers
SOURCE: Canon Pixma Printer
Unload all paper. Examine the feed track for any obstruction- paper fragment - cookie crumbs. Take a vacuum nozzle to it and give it a good suck out. Now feed a heavy weight paper/thin card through. Did it do the trick?
Posted on May 23, 2007
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Posted on Mar 04, 2008
SOURCE: False paper jam warning on Canon Pixma iP3000 printer
I have been using the Canon MP180 PIXMA for almost three years now without a hitch until I received a paper jam warning which I could not resolve. I Googled "Canon PIXMA paper jam" today and landed on this site. I turned the printer upside-down and shook vigorously. Out popped a small pebble-like bit of concrete which somehow found it's way into my printer. I guess our hardwood floor installation on the floor above had shaken up some old plaster and concrete bits that had lodged in our drop-down ceiling from our 3rd floor bathroom renovation last year and this little ****** came through an opening in our rec-room (where the computer and printer are) drop-down ceiling. A very strange sequence of events, that I would not have suspected, but happy to say that your advice here did the trick and the printer is a tough and trustworthy little printer afterall! Thank you. Dan in Canada
Posted on Aug 30, 2009
SOURCE: My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
http://www.fixya.com/support/t119769-false_paper_jam_warning_canon_pixma
To my surprise, it worked perfectly... and was great stress relief.
Posted on Oct 22, 2009
pineworks
  • 4041 Answers
SOURCE: canon pixma ip1980 service error 6000
Hi there
You can try this may help you.
These are the steps:
1. Turn On iP1980
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
To get Permanent , follow the steps here :
Manual Resetter canon Pixma iP1980/1900 Download
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 07, 2010
How do get paper out of canon mg3155 printer? It is jammed
Quote from "fixyourownprinter.com": The printer tools in XP, that came with the printer have some mantainance functions available. It just may be that the so-called roller cleaning operation may calibrate the timing, I don't know this for certain, but the error has stopped. I just ran the option where it fed 3 sheets through. Now things are working much better. If anyone out there has the same issue, try doing the same to see if it helps. I almost trashed the thing. I was watching the black Friday adds, and was thinking of buying a new one, glad for now, that I didn't. I managed to get the printer back together, now it says my ink is running low. You can try using a greeting card to push through any scraps of paper or broken plastic.
Dec 06, 2014 | Canon Office Equipment & Supplies
My Canon Pixma i4600 "ate" a sheet of paper. Although I was able to get all the pieces out again the printer does not move anymore. Instead, it shows support code 6a80. Can anyone help? Thank you.
The print head is locked
feed a piece of paper through the back and manually turn the white roller until the paper is 3/4 through. Turn the printer on and the printer should take the paper and run it the rest of the way through.
Sep 24, 2013 | Canon PIXMA iP4600 Color InkJet Photo...
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Foam fell out of printer now printer jams
There are no foams inside the printer for normal operation. Unless this is the one that was inside it during shipping but you were not able to remove it. In any case if you are not having any problems then you are good to go. dont worry about it.
Aug 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jam
Don't know if it's the same problem i had but its maybe worth a try. Mine is a Canon MP160 but again its maybe worth a try.
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Feb 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP160 showing paper jam, but none
hi
symptoms:
Solution:
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
91 people viewed this question
old marine
old marine
